I know, someone is asking another stupid wheel question, but I have to. I have 13" chevy wheels and wondering is the center section the same as 14" or 15". Talking about the section welded to outer rim. Was think of putting spider rings on, but nothing for 13" rims. Don't have 14" or 15" rim to measure if any difference. On Wheelkid web site, they list a size for rings, not sure where their measuring at on wheel. Also, on the push through cones, do they push through the hub center and if so how. When the wheel is bolted on, the rim fits up tight to the hub and axle st the center hole. I know, i should just contact Wheelkid, but I was just checking with some of you guys real quick. Sorry for the dumb questions, and thanks for any replys. P.S., just trying to dress up the steel rims I already have and save myself some cash.
I tried searching, but not much on here about 13" rims. I'll have to get some pics of what i'm meening. Maybe I should ask, will a 14" wheel hubcap fit a 13" wheel. The rims are on the 64' chevy II. Thanks, Scott
Are you looking for 13 inch "beauty" rings or the ring that snaps over the bumps on the wheel center and goes around the spyder cap? there is a set on Ebay, not cheap 310157926245 There is also a set of 13 inch trim rings for 13 inch Mercedes wheels that are damned expensive. Here, new = http://www.hubcapmike.com/2in-trim-...edium=Product_Search&utm_campaign=google_base
Actually both, but the ring that goes on the hump just outside a spider cap is what I was wondering about. The spider caps should be the same for all 5 on 4 3/4 bolt patterens even if it's a 13" or 14", 15" right? Do you think this portion of the rim is the same size on all wheels and the outer rim is the difference between 13", 14" and so on. Thanks, Scott
Sometimes it is the same and some times it isn't. Give me a call at 559-322-2128 and we'll figure out what you've got Thanks Jimmy
