It doesn't appear you have any making there way to valve seats or cylinders so I would think you are good to go.
No there none between the cylinders and valves just the usually water jackets to head bolts and theses two places.
Old timers would say that those cracks came with a Ford part number. Like the previously posted, no worries.
I didn't think they were a issue, just needed reassured. Any need to helicoil them or just use studs and sealer?
Most "no cracks" flat heads will have those cracks. It's like a car with "no rust" just means most of the panels are still there. Edit, don't use a tap to clean the threads and don't over torque.
Used number 2 Permatex per my machinist's recommendation. No leaks but I'm sure others will have other suggestions for a sealer.
