Projects Aarons 29 AV8 coupe build
Discussion in 'Traditional Hot Rods' started by Aaron D., Jul 27, 2016.
  1. greaser
    greaser
    Love this little coupe. Have you fired the engine yet? Would like to hear those pipes!
  2. Aaron D.
    Aaron D.
    Not yet Greaser, I’m getting close though. I’m working on running wiring so I can fire the Flathead up!
    louisb and 48fordnut like this.
  3. louisb
    louisb
    You using a kit for the wiring?
    --louis
  4. Aaron D.
    Aaron D.
    Yes, I bought the 12 circuit speedway harness. Made a mounting plate today to mount the fuse block and relays so I don't have to drill holes in the firewall to mount everything. Should be able to start running wires tomorrow.
    louisb likes this.
  5. louisb
    louisb
    Be interested to see how you do the wiring. I am just about to order the wiring for my project.
    —louis
  6. Aaron D.
    Aaron D.
    It will be my first wiring job of a complete car. There are a few things that are going to be challenging, a couple of them are: the inertia switch and relay for the fuel pump, the original 1939 ignition switch and start button running through relays. I'll figure it out one step at a time though.
  7. louisb
    louisb
    Yeah, I am worried about the 6v gauges. There is a nice basic wiring diagram in the Bishop book I plan to follow. Of all the stuff in building a hot rod wiring worries me the most.
    --louis
    Aaron D. likes this.
  8. Tim
    Tim
    from KCMO
    Used the same harness in my 46, I’d buy it again.
    Though it does come with enough wire to wire a 22 ft long car so keep in mind that you’ll be trimming a ton
    brEad and Aaron D. like this.
  9. Aaron,
    Moving right along. The lights turned out nice!! I have been eying those same lights.
    Thanks as always for the informative videos!!
    Brian B
  10. Aaron D.
    Aaron D.
  11. Aaron D.
    Aaron D.
    Been toying with dash ideas. Imagine this with a nice classy finish on it. It’s Bubinga wood from Africa and it will have a deep red tone to it.[​IMG]
    slv63, brEad, 48fordnut and 2 others like this.
  12. Tim
    Tim
    from KCMO
    I can dig it.
    I can’t recall, did you end up having to replace any of the wood in this car?
  13. louisb
    louisb
    It would look nice with the right color dash. You going to use any other wood accents for the interior?
    —louis
  14. Aaron D.
    Aaron D.
    Tim, all the wood was good, I didn't have to do anything with it.
    Tim likes this.
  15. Aaron D.
    Aaron D.
    I agree, the dash is in red primer right now, not a good color to go with the wood unfortunately. I haven't cut the dash yet though.
    I could run a regular 5 gauge Stewart Warner style panel and run the extra gauge I have on a little panel attached to the bottom of the dash. I don't know, i'm kinda unsettled on what to do.
  16. 48fordnut
    48fordnut
    Run all gauges on the same panel. My .02.
    I have the large S/W gauges 2 5/8, and the small speedo.
    39 Aaron NZ likes this.
  17. louisb
    louisb
    I feel you man. I went round and round on the dash for a while. I bought 4 different inserts and 3 different dashes, including a full ‘35 dash with gauges. Yes I have a problem.
    —louis
    brEad and 39 Aaron NZ like this.
  18. Aaron D.
    Aaron D.
    Haha, that made me laugh. At least I'm not the only one!
  19. Aaron D.
    Aaron D.
    Hmmm....[​IMG]
    slv63, brEad, Tim and 5 others like this.
  20. greaser
    greaser
    I'm thinking it'll look sharp... (and different)!
  21. Tim
    Tim
    from KCMO
    Looks good to me
  22. 48fordnut
    48fordnut
    Always another idea. Yours looks good.
    I think I will copy that. Probably not with good wood. .4 -2 5/8 gauges and a 3 3/8 speedo.
  23. Headlights look good! I like the way you work through it. Most build threads just show the end result. Your videos give a much better perspective.
  24. Aaron D.
    Aaron D.
    Thanks for the opinions guys. I think I'm going to use the wood panel, I can always go back and change it later.
    Thanks brEad.
    This wiring is kicking my butt, It's not that hard, but it takes forever when you're trying to make it look good.
    Aaron
    slv63, WTF really and louisb like this.
  25. Tim
    Tim
    from KCMO
    Yes extremely tedious
  26. but you'll be glad ya did it right..... bet your itchin to get er running, nice job so far!!!
  27. Kiwi 4d
    Kiwi 4d
    Just did a full rewrite on my buddys A coupe and he wanted to use a push button start and the original ( well to 37 ford anyway) column toggle switch. We probably did not have to as he has no real accessories to speak of , but took the load off the toggle switch with a relay also.
    Been through 4 English cable wipers and all have a failed park system, probably dodgy when new. So will have to rely on a digital park system .
  28. Aaron D.
    Aaron D.
    I sure am, cant wait to hear that Flathead sound.
    WTF really likes this.
  29. Aaron D.
    Aaron D.
    I wired up the stock 1939 starter button and toggle switch too. I used the horn relay that was incorporated into the wiring harness.
