Projects aa/fa fuel altered F.E. model a project
Discussion in 'The Hokey Ass Message Board' started by HILLBILLY'ED, Nov 27, 2010.
  1. HILLBILLY'ED
    HILLBILLY'ED
    Here is a project that i have been working on for a while. All steel chopped 5" ,frame certified to 7.50, F.E. FORD with 12-71 magnesium blower, powerglide...
  2. burnin53
    burnin53
    from cuba,n.y.
    Bad ass and then some,I love FE's!
  3. DIRTYBIRD
    DIRTYBIRD
    12 spoke Spindle mounts and an FE?....did you steal the blueprints for my future project??? hahahaha...Cool A!!!
  4. 67goingthing
    67goingthing
    Specs on the motor please!
  5. ummm, fucking wow! thats pretty nasty in a great way!
    wheres the photoshop gurus,
    was thinking how would it look with the motor back in the cowl a bit more? same pipes
  6. BlownMerc
    BlownMerc
    from Jerome
    AWESOME I want a ride!!!
  7. FrozenMerc
    FrozenMerc
    Now that is AWESOME!!!!
    Post some specs on the FE, PLEASE!
  8. GaryB
    GaryB
    from Reno,nv
    bitchin ride,go man go
  9. HILLBILLY'ED
    HILLBILLY'ED
    I'm going to run the thickest F.T. block i have found,.030 over with Oring grooves, custom Jahns 10:1 pistons {flat top with valve relief},steel F.T. crank with the snout turned down for a B.B.C. crank hub, Edelbrock CJ aluminum heads with a reciever groove cut in them to match the heads,Comp roller cam & lifters, Erson roller rockers.Blue Thunder intake with the 2" spacer and an adapter plate to mate the 12-71 to the 6-71 intake..I'm going to run 20% under on the drive for now to hold the boost down to about 20 - 25 lbs. I hope
  10. FrozenMerc
    FrozenMerc
    I imagine you plan on adding cross bolts to the block too?
    Do you know of the Ford FE Forum? Funky format with lots of good info and drag racing experience.
    http://www.network54.com/Index/10214
    Keep up the good work.
  11. That is one wicked ass Model A!!!
  12. dirtbag13
    dirtbag13
    get that thing done !
  13. brandon
    brandon
    thing looks bad ass.....thank god its not on a 125+" w/b chassis. :D proportions are right on.
    all its missing are some 16x13 big windows..
  14. Wow! What size are the back wheels & tires?
  15. BAD ROD
    BAD ROD
    Your gas mileage is gonna suck.
  16. HILLBILLY'ED
    HILLBILLY'ED
    rear wheels are 14" with 33x17 tires ,as for the cross bolt main caps, the F.T. block has no provision for the boss's, but on the good side it has more webbing..my brother is a machinist by trade and has built a main girdle that attaches to the pan rail with cap screws
  17. Mattbee
    Mattbee
    Man, that just looks awesome! Completely awesome!!
  18. What timing cover is that?
  19. "Hell Ya" is all I gotta say about that!!
  20. Wow, get it done so you can run it at the Meltdown Drags!
  21. lippy
    lippy
    from Ks
    Cool! Let's get that grille shell up there a little higher.:D That blower pulley is as big as the blower!! Everything thru the hat? Lippy
  22. HILLBILLY'ED
    HILLBILLY'ED
    I'm running a Nicson boat front cover for a fuel pump drive and lower mount,some one wanted to know what size the tires are,so i will add a picture..there big just like the blower pully..As for that ,fresh stripped big blower & a small motor,I was thinking if i under drive it the intake charge will stay cooler than a small blower running faster with the same boost...The grill shell is just fine,thats the look i was going for {my own}.....
  23. 1320stang
    1320stang
    from Edmond, OK
    Pro-Gram Engineering makes the 2-3-4 crossbolt main caps for the FE.
    A guy named Dave Shoe made a capsaddle for the FE, only a few were ever completed and not many were sold.
    A class racer named RJ Sledge tested one in a Stock class car, seemed to hold the bottom end together better, might be a guy on the FE Forum that got one would be willing to part with it.
  24. HILLBILLY'ED
    HILLBILLY'ED
    Thanks for the info, i've seen the pro-grams but the capsaddle is new to me..i.ll have to do some checking on that..thanks again
  25. abone1930
    abone1930
    Cool lookin ride, I see we got similar taste :D Luv the gasser coupe too.
    I just got mine in paint this weekend.
  26. dirtbag13
    dirtbag13
    lookin good !
  27. HILLBILLY'ED
    HILLBILLY'ED
    Drag car or street..have you ever ran it down the strip..
