Technical A question for the garage tool making gurus
Discussion in 'The Hokey Ass Message Board' started by HJLrulz, May 23, 2017.
  1. HJLrulz
    HJLrulz
    I know making something from solid stock is probably the strongest way, but, lets say i dont have the right thickness metal for the project at hand. How strong or weak would the metal be if i made something from a stack of similar metal, bolted or rivited together to the needed thickness?... the project im thinking of is not extremely high strength, or dangerous if it was to break, but does need to be strong enough to get the job done. ... any thoughts?
    Ps... im thinking about stacking sheet metal to get to 1/2" thickness, maybe 2" wide and about 15" to 20" long
    Herschel
  2. Probably depends on the end use,maybe 2 pieces of 1/4 inch.
  3. 19Fordy
    19Fordy
    Stacking or layering sheet metal is a "weak" solution, especially
    if you have any torque or bending forces applied.
    What tool is it that you're trying to make?
  4. oj
    oj
    The 'stacking' of 2 thickness' isn't the weak part, it is the bolts/rivets/weld etc joining them.
    Dino 64 and afaulk like this.
  5. Mike51Merc
    Mike51Merc
    I'm no guru, but your intended application needs to be known to fully answer your question.
    upspirate and 49ratfink like this.
  6. squirrel
    It's all in the design...you gave us no clues as to what it has to do, so we can't answer your question.
    C'mon, spill it, we can help you figure out how to do what you need to do.
  7. BJR
    BJR
    Are you thinking plywood, only metal?
  8. Mike51Merc
    Mike51Merc
    Dino 64 and 31Vicky with a hemi like this.
  9. If they are heated and forge welded together. Them dudes mix the molecules up man
    302GMC, Just Gary and gimpyshotrods like this.
  10. Strong enough to get the job done?
    I'm sure it will do serious damage to a entire swarm of flies before it fails.
    You probably could put a few good dents in a door skin with it.
    It will leave a mark on someone
    It might hold water
    Great door prop giving many years of service.
    2 pieces of 1/4" x2"
    Available at the local home center.
    HJLrulz likes this.
  11. gimpyshotrods
    gimpyshotrods
    What eeeeessss eeeetttt maaannn!?
    117harv and HJLrulz like this.
  12. This is like asking if .................................,well,can I?
    HJLrulz likes this.
  13. Wallaby
    Wallaby
    Surface tension makes it strong. Laminated sheets are stronger than a singe thick piece.
    The same applies to plywood; the thinner the sheets, the less resistant to bending it is.
  14. ya making your own leaf spring?
  15. gimpyshotrods
    gimpyshotrods
    Every metro area has a fabrication shop. Often there is more than one.
    Every fabrication shop invariably ends up with leftovers from jobs called drop.
    Some of my finest work has been done with drop. Get some.
    flatford39 and saltflats like this.
  16. HJLrulz
    HJLrulz
    Yeah, I was vague on the end use on purpose. I wanted the info given kinda general or generic because I have different uses in mind, different projects. The 1/2"×2"×15" dimensions is something I want to make that will be used as a lever, think "come along" or "winch" but without the ratcheting and cable.
    I've been reading the Homemade Tools thread and thought about making somethings using whatever i can easily obtain (free) and posting there. Also thinking maybe someone here that has more knowledge on riveting might donate some of that info for me to absorb .
    Right now I'm making a small power hacksaw from mostly scrap, I came across some black pipe, so im considering making a bandsaw and maybe some form of rotisserie, ( thats why I made the hacksaw 1st). I might post those there also as i finish them.
    Herschel
    Sent from my cell phone when I shoulda been working, using the H.A.M.B. mobile app
  17. HJLrulz
    HJLrulz
    This is kinda what I'm hoping to hear...lol
  18. HJLrulz
    HJLrulz
    I never thought of that!!!!!...... Now I wonder if i collected up enough knives, could i forge them together to make said leafspring?... now wouldn't that be a turn around...lol
    Herschel
    pat59 likes this.
  19. If your tool projects are successful, please post them here
    If your tool projects are successful, please post them here. I'm sure we'd all like to see them
  20. HJLrulz
    HJLrulz
    Oh yeah!,... the shop I work in "donates" scrap steel to quite a few of my wizbang wonders... i mean serious projects.
  21. saltflats
    saltflats
    from Missouri
    How much force on the lever?
  22. HJLrulz
    HJLrulz
    Lol,.... it's just an idea that I am looking into, nothing incredibly serious
    Herschel
  23. HJLrulz
    HJLrulz
    Yup,.. bingo
  24. mountainman2
    mountainman2
  25. HJLrulz
    HJLrulz
    Just arm strength
  26. HJLrulz
    HJLrulz
    I was thinking the same thing
  27. saltflats
    saltflats
    from Missouri
    Guess it depends on how big your arm is.
    May work..........maybe stack them up and then wrap it and bolt or rivet together.
  28. HJLrulz
    HJLrulz
    Im out in the garage and I'm looking at the sheetmetal, its anout .035" thick x 16" tall by more then i need long. Instead of cutting into strips first, what if i was able to fold it? If I can fold it into 16 layers i should get .500" thickness... or close to that... then i will still have to fasten it together to hold its shape and around areas of the pivot points and things. Thoughts anyone?
    Herschel
  29. HJLrulz
    HJLrulz
    ...ps also making a bending brake and possibly some kinda sheet metal roller
  30. Mike51Merc
    Mike51Merc
    I have a project that requires a rope. If my rope isn't long enough, can I tie two pieces of rope together? Will it be strong enough?
    HJLrulz likes this.
