Technical a little different 4x2 flatty weiand
Discussion in 'Traditional Hot Rods' started by jambottle, May 7, 2016.
  1. jambottle
    jambottle
    thought i would get your thoughts on this setup?
  2. jambottle
    jambottle
    volvobrynk and LOU WELLS like this.
  3. Hot Rod 50
    Hot Rod 50
    Cool. Better have a hell of a cam and some cubes to eat all that fuel. Gonna look awesome though.
    volvobrynk likes this.
  4. jambottle
    jambottle
  5. cs39ford
    cs39ford
    Hot Rod 50 is right and some adj jets also. Here's mine I run
  6. Hot Rod 50
    Hot Rod 50
    I did not notice that. I'm still learning about all these little carbs. 4 1 bbl carbs with a little cam might run pretty good. Damn sure look cool. What's the motor specs? I'm getting ready to build a 50 merc for my coupe.
  7. flathead4d
    flathead4d
    Where did you get the air cleaner screens for the frog mouth scoops?
  8. cs39ford
    cs39ford
    I made them , screen door screen , fine scotch brite pad , course wire to fit top of carb to keep everything in place. Scoop holds pad and screen in place. Keeps some dirt out. And big birds. Running them like that since 1990s
