am i right ? a distributor from any f/e will fit any other f/e right? there arent no shaft length or case diameter differences are there?
For the most part, yes- FT's are different, usually have governor stuff added, tach drive, and have larger pump shaft drives You might find an oddball setup that doesn't clear or fit right, the M/T crossram being one, but usually no problem
