The coupe I am building had a roll down rear window which I have eliminated. The wood that was around it seems too large (thick)now with all the hardware removed. Anybody got a pic of the wood installed in a non roll up coupe for reference. Hoping to alter the wood but a pic would be great or some input before I start this.................thanks.
Here's a few pics, you will need to use a standard 1928-31 rear window molding (coupe and sedan) not the deeper one on used for the roll down rear window ( that molding also fits 1930-31 sedan delivery back doors) later kb
That roll down window is quite desirable, do you still have it or any of the parts? Sent from my E6810 using The H.A.M.B. mobile app
Well, I know I have the glass and the crank somewhere. I just saw the pan this week also. I will find all the pieces and put up some pics. Thanks for the reminder. So much going on with this build now that a lot gets put away and forgotten
I have the regulator somewhere and the drip pan and glass. Also, the rear package tray. I have the original top wood piece and the two side vertical pieces. The pan would need a repair in the center and the water outlet needs to be reattached. I will never use any of this so if anyone would be interested let me know.
memory is part time help... leftover '29 and some '30 murray 4 screw door window regulators were used for the rear window regulator, don't remember left or right... garnish is thicker front to back... HIH.
MrT, the previous owner had converted to a trunk. It will remain for sure. Smitty, It looks like they used 3 and 4 bolt regulators in the back window. All of mine are three bolt.
I tore the shop apart and cannot find the regulator or any remaining wood pieces! You know how things get misplaced, very aggravating to say the least. As I remember three years ago when I tore it all apart that the wood was rotten and most likely I tossed it....now the regulator is a mystery.
