94s 97s on sbc
Discussion in 'The Hokey Ass Message Board' started by greatlakesspeedshop1, Jan 3, 2010.
  1. greatlakesspeedshop1
    Hi all, I was just toying with the ideal of running 94s or 97s on my sbc. Would this be a pain in the butt ? or is there a setup that works well ?
    I love the looks of this setup (4 barrel intake with the 2X2 adapter). I would also like to run a mild cam to get that sought after rumble.
    OK lets here your thoughts
      358.4 KB
  2. dickster27
    dickster27
    from Texas
    Very doable. Check my web site gallery pix for some ideas.
  3. Won't need to worry about over-carbuerating.
  4. strombergs97
    strombergs97
    Happy New Years..Here is one I built on a custom 4 barrel intake. I used Stromberg 97s..
    Duane.
  5. I used to run two 94's on an adapter on my 350 sbc, they were linked in unison and only the front carb used the choke. It ran like a raped ape for the low to mid range but it ran out of steam pretty quick while trying to pass on the high-way or other higher rpm running. I want to say that both carbs would only flow about 400 cfm ( correct me if I'm wrong ) I replaced them with a AFB and sold the carbs to a guy with a stocker 36 with a flat-head and he is happy as can be. If you have a 265 or 283 thats basically stock, they might work out real well but not really for larger displacements. Just my 2 cents, Mike.
  6. uncle max
    uncle max
    Happy HALLOWEEN :D
