Anybody know if it`s possible to get a axle bearing for a ford 9 inch 28 spline with the outside diameter of the small bearing housing and the inside diameter of the big bearing housing? So i essence i need to put some big bearing axles into a housing that uses the small bearing. Thanks.
To use a 1.531" big bearing axle (28 or 31 spline) in a small bearing housing use the Moser bearing. http://www.moserengineering.com/smal...market-id.html
