Technical 9” 3rd member
Discussion in 'The Hokey Ass Message Board' started by Firedup, May 18, 2019.
  1. Firedup
    Firedup
    from Oregon
    72E71890-ADD2-4A05-8E9F-E7A4E498B0C8.jpeg A406F6F9-A878-4E03-BF40-B13CE8DA83FE.jpeg CAC9128D-44CD-4799-8D28-5639B7A34CBB.jpeg 5F16E047-11D9-433F-AF9D-1D63A9AE582E.jpeg So I picked up this 3rd member from a guy, it was advertised as a 4.4:1 ratio. I couldn’t pass on it for the price. Looks to be in good shape. Coming to closer inspection I see that it is stamped with a 42-10 ratio, witch should be 4.2 ratio. I’m curious about these oddball ratios and not a whole lot of information on them from the searching I’ve done. I plan on trying this 3rd member out with my gasser build. BBC 454 with TH400 tranny and roughly 30-31” tires. What do you guys know about these?
  2. Early Bronco 6 cly. ?
    Firedup likes this.
  3. squirrel
    ring gear is from 1971 or later, according to the engineering number
    might work ok, I'd probably check the tooth contact pattern, inspect the bearings, and replace the differential with a locker or spool or something, depending on intended use
    Firedup likes this.
  4. RmK57
    RmK57
    Early Broncos had either 4.11 or 4.56.
    Ford had a 3.91 and 4.30 for their hipo ratios but they should be in a N case carrier.
    Could be someone put that together from spare parts.
    Firedup likes this.
  5. saltflats
    saltflats
    from Missouri
    Have you counted the teeth?
    sidevalve8ba and Firedup like this.
  6. Firedup
    Firedup
    from Oregon
    Definitely a locker or spool in the future. I may just run it though
  7. That's why I placed question mark. Goggle can not always be trusted. That said. There are several other people asking the same question in regards to 4:20 gears. So they are out there.
    Firedup likes this.
  8. Firedup
    Firedup
    from Oregon
    Not yet lol.
  9. Firedup
    Firedup
    from Oregon
    I will count the teeth when I get a chance. o_O
  10. gimpyshotrods
    gimpyshotrods
    For some reason, that seems to light up a memory of being a 2.75:1 gear.
    That would be 44-teeth on the ring, and 16-teeth on the pinion.
  11. ^^^^^ That did come up during the short while I googled 4:20 Ford gears.
  12. onetrickpony
    onetrickpony
    from Texas
    That 4210 is part of the engineering number. You should have counted the teeth before you bought it.
  13. gimpyshotrods
    gimpyshotrods
    If it is a 2.75:1 gear set, I have a 2.50:1 gear set, if you want to make it worse. :rolleyes::p
    swade41, mgtstumpy, Just Gary and 2 others like this.
  14. oj
    oj
    That case isn't very strong, it has just the single web. I wouldn't spend any money on it to use in a gasser, it won't last long launching a big block.
  15. flamedabone
    flamedabone
    Judging only by how thin the ring gear is, I'm betting it is a 2.87 or 300:1. Definitely a single spinner because the ring gear bolt area is flat instead of bumpy. I'll go one further and guess it is 28 spline, only because they are more common.
    I don't swear my information is 100% accurate, because sometimes I'm full of shit, but I bet it's pretty close.
    Hang on to it, you will need it for something someday.
    -Abone.
    mgtstumpy and Just Gary like this.
  16. Yep, the 'basic' part number, probably found on all ring gears regardless of ratio, although I suspect this particular number is for 9" axles only.
    The 'D' is the decade ('70s), '1' is the year (in this case, '71), the 'A' is generic Ford, and the 'W' is axle/driveshaft group. Then the 'standard/basic' part number from within that group, and lastly the 'A' is the first revision.
    If it was a body part, it would be six numbers instead of four for the 'basic' number, with the first two identifying the specific model (Ford, Mustang, Fairlane, 2-dr, 4-dr, etc), and may have a color indication after/in place of any revisions.
    Some mechanical parts (primarily distributors and carbs) would have the basic part number, then an additional number denoting the specific application, either stamped in or on a separate tag. Some OEM-installed engines/transmissions would also have a partial VIN stamped on them, but not all.
    Also keep in mind that Ford didn't change casting or part numbers yearly; they merely denote the first appearance of that particular part. As long as the part was substantially unchanged, a part would keep the same number.
    deucemac, oj and gimpyshotrods like this.
  17. Charlietruck62
    Charlietruck62
    As has been said the D1AW 4210 A is the engineering number that tells me it was designed in 1971. Probably used for several years thereafter until the next redesign. The C6AW number was designed in 1966 and used for many years and the case was done in 1967 etc. Count the teeth and divide by pinion teeth. From looking at it its probably a 2:75 or so gear from a 70's ford car and not a locker.
  18. Ive found 390 and 411 ratio 9 inch in old late 50's and early 60,s stick shift cars & trucks. the auto trans had 300 and a six auto a 350. the FE stick trucks had 325 ratio.
    anothercarguy likes this.
  19. big duece
    big duece
    from kansas
    If they were 4:11 or lower, that ring gear would be awfully dam thick...
  20. DIYGUY
    DIYGUY
    from West, TX
    I see a bunch of rust in photo 3. I wouldn’t use them.
  21. Marty Strode
    Marty Strode
    We ran a 7.33 gear in a circle track car, it was real thick !
    swade41 and gimpyshotrods like this.
  22. Kan Kustom
    Kan Kustom
  23. big duece
    big duece
    from kansas
    Never heard of a 4.4:1 ratio, so the selling was all wet. Count the teeth.
  24. Jalopy Joker
    Jalopy Joker
    would not run as is for that ride - never seen a 9" with that type of webbing but, I am no expert - kevinstang.com is good source for Ford differential info
  25. saltflats
    saltflats
    from Missouri
    People have different ideas of what a gasser is. ;)
  26. raven
    raven
    I’ve got a 4:11 in a locker third member if you’re interested.
    I even have a 4:56, too.
    r
    Firedup likes this.
  27. Firedup
    Firedup
    from Oregon
    I was after some 4:11 gears . I saw the 4.4 and 4.2 ratio and thought I’d give it a go. Obviously I know nothing about them:confused: I think I did alright for $120
  28. choffman41
    choffman41
    There may be another stamping on the ring gear designating the tooth count.
  29. Ericnova72
    Ericnova72
    IMO you got hosed...not the gear you were told it is, weak single rib case, open differential....not even worth $50 bucks
  30. RmK57
    RmK57
    If there 28 spline axles your 454 is going to make short work of them, even shorter if you have slicks. The C7AW case is probably the weakest one in the 9 inch pecking order also.
    One good thing is your using an automatic.
