8ba FORD FLATHEAD DRIVETRAIN SOLD SOLD SOLD!!!!!!!!!!!! SOLD Pending Payment I have a completely updated and rebuilt 8ba Ford flathead drivetrain for sale. This drivetrain now sits in my body off restored ‘36 coupe. The complete setup includes the engine, top loader transmission, and complete banjo rear end. Everything is newly rebuilt or new, with only the highest quality parts and workmanship. There are absolutely no issues or hidden problems with any part of this driveline, period! I have been a longtime Ford flathead enthusiast and also have a ‘30 coupe with an 8ba flathead. However, I have been presented an opportunity to go in a completely different direction with this car, and I cannot turn it down. Therefore I am selling this complete driveline, including all the items listed below. If you have a 1935 -40 Ford, this is a direct, bolt in, ready to run setup. It’s complete from fan to rear end. It does not get any easier than that. This set up can of course be used in any other early year ford with some changes. The pictures are of the ‘36 as it now sits, and it will remain together until the engine is sold. Those who are interested will be able to ride in the car, see what they’re buying, and won’t have to trust my word whether the engine runs perfect, smokes, stalls, knocks, sputters, overheats, etc., etc., etc. We’ll go wherever, city, highway, etc. until your satisfied with the quality of what your buying. When it’s bought, I’ll pull the drive train. Obviously, I prefer to sell this as a complete unit to one person. However, if it doesn’t work out this way I’ll of course part out the engine, transmission and rear end separately. I’ll start a list of who wants what, but nothing will be removed until the engine is sold. This is a quality setup. ENGINE Very strong running, absolutely issue free 285 miles on total rebuild 8ba 24 stud (using 59ab heads and crab distributor for earlier look) 4” Stroke .60 over 265 cubic inches Schnider Cam New; valves, lifters, springs, bearings, pistons, rings, oil pump, etc., etc. Edelbrock Heads Offenhauser 2x2 Intake Stromberg 97 Carbs (Both carbs were sent to Max Musgrove in Salt Lake City Utah for rebuilding. Max is the long time accepted authority on 97s in the USA) Stromberg Linkage Stromberg Fuel Connectors Fuel Pressure Gage Fuel Pressure regulator Electric fuel Pump New Water Pumps New PowerGen Alternator w/original ‘36 Mounted Fan New PowerGen Starter Rebuilt Crab Distributor w/Vertex Condenser. (Distributor was sent to Jim Linder in Indianapolis Indiana for rebuilding. Jim is the well known rebuilder of Early Ford distributors.) New Matched Coil, Resistor and Ford Starter Solenoid Resurfaced Flywheel with New Starter Ring Gear 8rt Bellhousing New Clutch Disc and Pressure Plate from Fort Wayne Clutch. USA Made (none better) Reds Headers Remote Oil Filter New Belt New Radiator Hoses w/Stainless Tubes New Custom made Plug Wires New Motor Mounts and bolts Every Nut, Bolt, Stud, Screw, etc. is New This is absolutely the complete ready to run motor, with every one of it’s accessories. What you see in the pictures is what you’re getting All that’s needed is for you to connect the battery to the starter and the coil to your ignition wire. Start it up, your done! TRANSMISSION Completely Rebuilt 1939 Style Top Loader with Later Updated Gear Set and Synchros Entire Gear Set was sent to Mac VanPelt in Ohio for inspection and replacement parts. VanPelt is the accepted authority on Early Ford transmission. Rebuilt 1939 Double Detent Shifter New Federal Mogul Throwout Bearing and U Joint New Transmission Mount Closed Drive REAREND Complete Closed Drive Banjo Rear End, Drum to Drum, Wide Five drums and Wheels Included Front Wide Five Drums and Wheels included to complete the Wide Five set) ‘36 Radius Rods New Posies Reverse Eye Super Slider Spring New Posies Shackles and Bushings New Ford Wheel Bearings and Seals New Pete&Jakes Shocks New Brakes New Raybestos Wheel Cylinders Brakes and Drums were sent to the Brake & Clutch Center in Tampa to be arc matched as a set Again, this is a complete, newly rebuilt, driveline package. NOTHING has been stripped or removed from the engine, transmission or rear end! If it’s attached to it, it goes. The only thing you need to supply is the drive shaft/torque tube. It cannot get any easier than that. $7,750 For the complete drive line
