Hi, I have been reading up on this and I wanted to check with you all to see if I am on the right track. Putting together a 276 8BA Flathead to go in a full fendered Model A coupe w/ a '39 style transmission. Will the following combination work? 8BA flywheel - Lightened to around 20 lbs - Redrilled for Long style 10" clutch and PP (seems to be readily available) The car is more of a cruiser so I want to stay away from an aluminum flywheel. Thanks, --louis
