'86 Z-28 CAMARO SBC MOTOR "REBUILT" WITH 3,800 MILE'S. 305 C.I. EDELBROCK TORKER II ALUMINUM 4 BARRELL INTAKE MANIFOLD, 600 CFM. HOLLEY CARB. ( NEW PART'S ) CRANE 1.5 BILLET ALUMINUM ROLLER ROCKER'S, STUD GIRDLE, ALUMINUM POLISHED FINNED VALVE COVER'S, ALUMINUM POLISHED VALVE COVER SPACER'S, CHROME FINNED WINGED HOLD-DOWN'S, M-77 HIGH PRESSURE OIL PUMP, REAR MAIN SEAL, PAN GASKET, INTAKE MANIFOLD GASKET SET. NEW OIL PAN, HOLLEY HIGH VOLUME CHROME FUEL PUMP, HIGH PRESSURE FUEL LINE, STEEL #10 MICRON FUEL FILTER, (NEW) 8 INCH K & N S/S AIR FILTER, (NEW ) 168-TOOTH BALANCED FLEX PLATE (NEW) ARP FLEX PLATE BOLT'S, NEW TRANS-TEK TORQUE CONVERTER. (NEW) HI-VOLUME WATER PUMP, (NEW) POLISHED 3-RIB "V" BELT PULLEY. (NEW) BILLET HEI DISTRIBUTOR W/65,000 VOLT COIL, (NEW) RED 8MM. EXTENDED BOOT ACCEL SPARK PLUG WIRE'S, AC DELCO SPARK PLUG'S. ALL NEW BOLT'S. BLOCK HAS SIDE & FRONT MOTOR MOUNT CASTING HOLE'S. GREAT SMALL BLOCK MOTOR FOR ANY VEHICLE. E-MAIL FOR PIC'S [email protected] TEL: #631-326-7510
