Time to go get my donor car #1. I'm gonna pull the eng/trans, rear end, front clip... what else should I take? steering? Anybody need anything? Leftovers are free for the taking.
Sorry, column shift. I won't forget the radiator. I'm gonna have quite a pile of crap in back of the garage.
hang on to the rear spring/hangers too. they just unbolt from the frame/unibody. damn handy to have around!
I used the steering column and swinging pedal assembly in a 56 f-100 .....if you don't mind a brake booster hanging off the firewall. Stopped great!
The wheels should be 5 on 4 1/2".The center hole is slightly larger than the Fords.Some of the street rod guys use Volare rotors to get the Ford bolt pattern,then find their wheels don't quite fit.
