I have a 700r4 in my 54 Lincoln Capri with a 317 Y-block. It has a Wilcap adaptor for the trans. When I put it into drive it seems really harsh. When I put it in reverse its really smooth. Just engages real light and perfectly. Drive is immediate and like a clunk. Is there an adjustable modulator? What the hell have I done wrong? Any ideas??? Thanks
Uh, thats what you get for putting a GM trans behind a Yblock? I don't know - typically I've seen that clunk be caused by too high of idle speed. Sorry, I got nothin...
did u adjust the TV cable b4 u drove it???? its something that should be done or u could burn up the tranny......joe these should help you, http://www.tvmadeez.com/article/index.html http://purplesagetradingpost.com/sumner/techinfo/techinfo.html
Oh, shit - I forgot about the Tv cable on those things. Make sure that is adjusted properly or it could cause exactly what you describe.
Thats exactly what I needed guys. I'll set that thing when I have the waterpump back on and its running. Bort62, The issue happens at all idle speeds and I also know its not an idle related problem because it does not occur in reverse and that cable isnt adjusted properly because there is a harsh downshift also. Thanks guy. Wish me luck.
don't drive that thing untill u adjust that cable or u'll have pile o'Junk. hopefully u didnt do anything to it since the cable hasnt been adjusted...joe
wow. check that TV cable. Full pull at WOT is needed. read the Purple Sage web site pages provided by the link posted.
I agree 100% what ever you do SET UP THAT CABLE PROPERLY! Take it from someone who's been there done that. I toasted two trannys in my 64 Chevelle before I knew what I was doing. I now have the under carb plate and bracket from boetie overdrives. Followed their instructions (with a pressure gauge - important) and the thing works great.
