Technical 6v / 12v cigarette lighter is there a difference?
Discussion in 'The Hokey Ass Message Board' started by FastLivin, May 6, 2019.
  1. FastLivin
    FastLivin
    Will a 12v cigarette lighter work in a 6v car?
  2. Not correctly.... It won't draw enough current to fully heat up, and it won't 'pop out' until it does...
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    ^ this.....It will only get half as hot as it should when powered by 12volts.
  4. 54vicky
    54vicky
    no that is why they make 6 volt that are marked as such.not marked may work if 12 volt on 6 volt
  5. BJR
    BJR
    You will half to use 6 volt cigarettes even though it's a 12 volt lighter. For some reason the lighter knows!:p
    56don likes this.
