Projects 65 Ranchero Southeast Gasser build
Discussion in 'Traditional Hot Rods' started by colbyw, Dec 28, 2017.
  1. PS. Make sure to run a tonneau cover, or keep the tailgate down, otherwise you'll be dragging a big air brake down track.
  2. rawcjw19
    rawcjw19
    That’s what Colby read also. We get the chassis figured out we will set it on the scales. We may have to add quite a bit of weight.
    Thor1, loudbang and Gammz like this.
  3. bob cowan
    bob cowan
    SEGA is real stickers on the rules so keep this in mind
  4. ..or run @ 2325 with a 294" (289 crank). With 500 HP it'll run the same as stated earlier. If you are gonna be fast with a 2.78 low top loader, and a 2.870-3.010 stroke crank, it's gonna need some serious rear ratio, and a little bit of flywheel weight.
    Thor1, rocketsled59, loudbang and 2 others like this.
  5. powrshftr
    powrshftr
    Ric raises an excellent point right there:
    When I was running the 302 in my car I was leaving at 6200rpm and the 3.70 gear I was using was bogging the motor waaaaaaaaaay down on launch.
    You guys will be running a ton more gear than that,but it illustrates the point:
    Small motor=limited torque
    Steep gears+rpm(!)=WIN
  6. rawcjw19
    rawcjw19
    If I am reading correctly C gas is 2500 min
  7. Doctorterry
    Doctorterry
    This has me excited! I'm 20, but I started my altered wheel base chevy II a year or two ago. It's coming slow, and I'm poor and in college. But guess what? That's how you learn to work with what you got. I reuse and make a lot of stuff I can't afford to be. Enjoy these moments, it's gonna be fun!
  8. I didn't even think about the min. Weight. So, you get a 50lb weight break for the tunnel ram, so I assume if the minimum is 2500, then you get the cubes for 2550, because of the tunnel ram. That makes it 318" engine. 4.060 x 3.075 (you can offset grind the crank to 2.000 journal, while increasing the strike .075. This combo should make 530-540HP with the same ET potential as before. You might think about 2600lbs/331" combo, then you can have a nice interior, and put weight wherever it's needed.
  9. colbyw
    colbyw
    [​IMG][​IMG]
    Made some changes to the frame drawing and cut all the metal, going to put it all together this weekend and start on the ladder bars next week once we figure out where the engine will be placed. If anyone has any measurements on the stock position of the engine it would be much appreciated.
    Thor1, catdad49, TFoch and 2 others like this.
  10. southcross2631
    southcross2631
    I am going to start with a 5.57 gear and a 30 lb. flywheel . With a 28 inch tire and a 2.78 1st gear.
    I am building a 297 inch motor. Probably not enough gear ,but we will find out.
    Back in the day when we ran G/Gas with a 302 inch Chevy we ran a 6.50 gear with a 2.88 1st gear Doug Nash and a 31 inch tall tire. Left the line at 7800 and shifted at 8800 We weighed 3420 lbs. The track prep was not as good and we would change flywheel weight to compensate. We carried 3 flywheels with us all the time and the 3 guys could change one in less than an hour.
    bchctybob and Thor1 like this.
  11. Gammz
    Gammz
    from Lincoln Ne
    What are you looking for exactly? Ours is in stock location. I’ll be out in the shop today. I can try and get something for you.
  12. colbyw
    colbyw
    If you could do it from this point to the front of the black it would be much appreciated.
    Thor1 likes this.
  13. colbyw
    colbyw
    I ment the front of the block
    Thor1 and loudbang like this.
  14. pumpman
    pumpman
    Watching kid, give it hell!
    Thor1, loudbang and colbyw like this.
  15. Mike Colemire
    Mike Colemire
    Make you a bed cover out of alum, have it hinged so 1/2 of it will raise or all of it. Bead rollit or even better punch some louvers in it. Going to be a nice car.
  16. southcross2631
    southcross2631
    If you look at the pictures that I sent you of my old Falcon on page 1 of your thread the motor was 8 inches back from stock. I hope that helps.
    Thor1 likes this.
  17. colbyw
    colbyw
    Trimmed some more metal to make space to put the frame under the car,set the engine placement to figure out where the front ladder bar mounts will be and going to put those in this week. I am trying to make the ladder bar crossmember have the driveshaft loop in the middle so that’s why I need to find out the engine placement, it’s sitting about 4 inches higher than it will be permanently mounted.
    Thor1, TFoch, catdad49 and 1 other person like this.
  18. What is the engine set-back rule in SEGA? I remember that ages ago in NHRA it was 10%.
  19. colbyw
    colbyw
    Yeah 10% is the max setback I’m shooting for around 6%
  20. Gammz
    Gammz
    from Lincoln Ne
    Trying to reply to your pm and it keeps crashing. It looks to be about 21 7/8” to the front of the block. [​IMG]
    Thor1, loudbang and rawcjw19 like this.
  21. Gammz
    Gammz
    from Lincoln Ne
    I must apologize for not getting this done for you last weekend. He suspension job on my daily kicked my ass . If ya need anything else hit me up. Good luck kid!!
  22. colbyw
    colbyw
    Thanks a lot
  23. Gammz
    Gammz
    from Lincoln Ne
    Now hold on a second. Where and when did you score the fully dressed out tunnel ram!?
    Thor1, loudbang and saltflats like this.
  24. colbyw
    colbyw
    I’ve had it sitting around for about a year in the pile of other parts collecting dust
  25. colbyw
    colbyw
    I’ve had the whole car for a little over a year and I’ve been slowly collecting all the ford parts I could find
    Thor1, enloe and loudbang like this.
  26. Hombre
    Hombre
    Signed on, This one is going to be fun..
  27. Cshabang
    Cshabang
    my fully dressed nearly all steel (glass hood) 65 Comet with full interior weighed 2950 with me in it back when I was about 150 pounds. That was with a 289, and a C4. I did nearly NO lightening on the car back then...Getting creative will get you below your minimum easily. Then add your weight in where it will make it hook
    Thor1, loudbang, Gammz and 2 others like this.
  28. colbyw
    colbyw
    Two people can pick the body up as it sits and we still have some metal to take off
  29. blownhemi48
    blownhemi48
    from Bergen NY
    I seem to recall that Hot Rod magazine dispelled this myth through wind tunnel testing on a pick up they were running on the salt.
  30. Gammz
    Gammz
    from Lincoln Ne
    We dropped the gate on ours at the Meltdown and didn’t make any difference in time or MPH. Now we aren’t running fast as the speed of sound either so maybe that makes the difference
