'64 galaxie engine swap
Discussion in 'The Hokey Ass Message Board' started by TANNERGANG, Feb 26, 2012.
  1. Boneyard51
    Boneyard51
    Right on COG
  2. Remember that you don't necessarily need a 390 block; the 360 truck block is the same bore as a 390, and other than one additional motor mount bolt location, is identical...
    chryslerfan55 and Clay Belt like this.
  3. Rusty O'Toole
    Rusty O'Toole
    I would be tempted to overhaul the 352 if the rod isn't sticking thru the block. According to all reports they are a tough, long living engine. Chances are a set of rings, bearings, gaskets, timing chain, oil pump and a valve job will set you up for another 100,000 miles .
    Summit offers an overhaul kit (no pistons) for $245 or a 360 rebuild kit with pistons for $422. With machine work, paint, etc you might have a rebuilt engine for under $1000. I doubt you could put in a second hand late model for that little.
    https://www.summitracing.com/int/se...ild-kits/make/ford?retaillocation=int&page=51
  4. Clay Belt
    Clay Belt
    Just a thought here, didn't Ford make a big block engine into the 1990's with fuel injection?
  5. Those were 460s, which first appeared in '88 in trucks to the end of production in '97. The 429 disappeared in '74. By 1983, the only pushrod Ford V8s available were the 302, 351W, and 460.
  6. Deuces
    Deuces
    I'd stuff something like this in one of those....:rolleyes: download (3).jpg
  7. If I owned something like that. I would put it on display in my living room.
    bobss396 and Deuces like this.
  8. Beanscoot
    Beanscoot
    "is there any late model engine/trans swap thats a direct bolt in?"
    No.
    I agree with the suggestion of a 390/C6. It is a direct bolt in, but not "late model". If you could find a 428 at a reasonable price, that would be even better.
    Center of the Galaxie likes this.
  9. All good info, but he's probably figured it out by now, (6 year old thread)
    X38 likes this.
  10. F-ONE
    F-ONE
    from Alabama
    FE, Smallblock,385 series.....whatever is chosen needs a Flux Capacitor.
  11. Boneyard51
    Boneyard51
    Man , I didn’t Even look at the date of the OP. Wasted replies! Bones
  12. Post 25 resurrected it, the guy with the '64 wagon.
  13. SilverJimmy
    SilverJimmy
    There also is the option of putting in a lower first gear in a C-6 which will wake up a big car like that and still give good cruise mpg. Not very expensive and you would probably be freshing up the trans before the swap anyway.
  14. Boneyard51
    Boneyard51
    Jimmy , could you give me some more info, how to,where to get gears, to to this? Thanks in advance, I made be redoing a C6 shortly. Bones
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    The gears can be had from an E4OD.
