SOLD 1960’s T Bucket Project Really cool time capsule T Bucket with all the right parts. I got it from the original owner’s nephew. According to the nephew it was built in the late 60’s by Freddy Courtney who owned Freddy’s Speed Shop in Apple Valley CA. He had built and drag raced similar T’s but the nephew said he never finished this one. It has an original steel body with a shortened A or T bed welded to the back. The door opens and latches. There is no floor or firewall. Includes the stock height windshield. The main rails of the frame appear to be modified Model A. The rear end is 55 Chevy with a Model A spring and shortened 35/36 bones. Up front is a V-8 60 axle with custom built hair pins. Spring perches are the fronts of 35/36 wishbones turned around to put the spring behind the axle. The front spring has tapered ends like the old Hollywood Spring CO made. Shock mounts are F1. The steering box looks like a Ross with a T column and wheel. It has a GM duel master cylinder so you can run a 4 speed. Drag link and tie rods are there-even the brake lines are run. This is a well designed and built chassis. Custom brass radiator came with it but I’m not sure if it was part of the original build. The wheels and tires are pure late 60’s Bad Ass. Rear wheels are 15x10 magnesium 5 spokes with M&H Racemaster 9.00-15’s. The front wheels are spindle mount 12 spoke Americans with little 125-15 Perellis. The tires have never been run. $6,500 Can deliver to Lonestar Round Up Call 865-755-7019
