.60 overbore on a Ford 5.0 ?
Discussion in 'The Hokey Ass Message Board' started by oldskooloutlaw, Apr 13, 2010.
  1. oldskooloutlaw
    oldskooloutlaw
    from Tulsa
    I have a deal on a set of grant forged .60 over pistons for sbf, is that pushing it too far for a daily driver? Thanks Guys :confused:
  2. thadeal4real
    thadeal4real
    from FRESNO, CA
    i dont think so id run it
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    Have your block sonic checked... 0.060" is max for SBF - if you have core shift at all, you may not be able to bore that far.
  4. 40fordtudor
    40fordtudor
    did it---it heated. i don't think a good price on the pistons should influence--
  5. Henry Floored
    Henry Floored
    What year? Just so you know the 5.0 Ford, round about 1986 (when they went to roller cam) recieved some block upgrades. One of them was an oval shaped outer circumference on the cyl bore to give increased thickness on the thrust sides of the bores.
  6. dirtbag13
    dirtbag13
    yeah i don't think i'd go for it just cause you can pick up a set cheap ! i bought a whole engine .60 over cause i got it cheap and am now having 2nd thoughts ! if anything happens its junk ! .40 is the most i like to see them !
  7. oldskooloutlaw
    oldskooloutlaw
    from Tulsa
    Thanks for the info I don't need any more shop anchors.
  8. Deuces
    Deuces
    They may be good for 351W marine/truck block if used with a Scat 3.85 stroke crankshaft... Check into it! That should get ya about 399 cubes out of a Windsor. :)
