Technical 60 F100 302 Swap
Discussion in 'The Hokey Ass Message Board' started by Superoptimis12, Feb 4, 2018.
  1. Superoptimis12
    Superoptimis12
    I'm looking to swap a 302 into my 60 F100 and I was wondering what oil pan I need to use. If anyone's got an answer for me that'd be great.
  2. LM14
    LM14
    from Iowa
    Depends on what is done to the front suspension. Lowered or MII or something like that you will need a rear/mid van/4x4 pan or fox body Mustang dual sump pan. Deepest part of the sump is right over the axle.
    I did a MII on my '57 and had to use a dual sump pan.
    SPark
  3. 410merc
    410merc
    I;m doing it right now on a 1960 f100 used the stock pan front sump I believe
  4. Superoptimis12
    Superoptimis12
    Are you sticking with the stock front suspension?
  5. fiftyv8
    fiftyv8
    from CO & WA
    I did an engine swap for a SBF 302 in my 1960, but had already installed IFS setup and had trouble working out an oil pan that would work, so I ended up using a SBC engine with a T700R4 because it worked out better for me.
  6. Superoptimis12
    Superoptimis12
    I'm going good with the original front suspension for more information.
  7. Mine has a Jag front end and I ended up using a fox body rear sump.
  8. 410merc
    410merc
    yes , my grandpa bought it new, so I don't want to modify it to much, i'm also using a automatic trans
  9. LM14
    LM14
    from Iowa
    The fox body pan will give you the most clearance, a van/4x4 pan would be the next best bet and a regular front sump pan would be the closest. They all should clear a beam axle but the front sump would be the closest to it.
    SPark
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    fox body/passenger car pan will be your best bet
