58 Olds rear end
Discussion in 'The Hokey Ass Message Board' started by doubledawg, Jul 4, 2013.
  1. Can anyone provide me with a good picture of the drum brakes on a 58 Olds rear end? My project car came with the 58 olds diff already mounted but with no brakes on it at all. Here are some pics of the diff as it showed up in my yard. a picture from an old service manual or something would be great. I've ordered up a bunch of parts but I don't know for sure that I ordered everything thats missing. All that came with it was the backing plates.
  2. Fedcospeed
    Fedcospeed
    Id like to know also.Got one buried in my trailer
  3. Talk to Brad and Sue at Fabcraft 800-208-8242 They are very good people,very knowledgeable and WILL help!!! They specialize in these rearends! Tell'em Redline sent ya! Let me know how it turns out! R~R
  4. 56sedandelivery
    56sedandelivery
    Your local library should have at least a few MOTOR'S or CHILTON'S manuals, or look up "brake diagram" on the web. Butch/56sedandelivery.
  5. Thanks Butch. I never even thought of checking the library. when I googled brake diagram 58 olds it brings up this very thread. lol. But for now, I'm off to the library,
    thanks again
    Darren
  6. TagMan
    TagMan
    I think I have a set of built up brake drums for the '58 Olds rear axle I have in the barn. I'll check and post pics this afternoon, if it's still there.
  7. black 62
    black 62
    from arkansas
    i always use 70's - 80's chevy 1/2 ton stuff---backing plates and all...
  8. Here's a couple of pictures out of an old Motor's Manual. The pictures were in the Olds section but they look pretty generic to me. Anyway the Olds brakes are just normal Bendix type brakes. The rear brake picture is '59 up self adjusting type and the other is manual adjusting. Should give you a good idea on how either style goes together. Just remember the primary (short) shoes goes to the front.
  9. TagMan
    TagMan
    Here's a pic of the backing plate assemblies that came with my axle. Doesn't look like they're complete (the guy I got it from was using the axle for drag racing), but I'll post the pic in any event.
  10. vetrod62
    vetrod62
    I do not know what those backing plates are off, but they are not Olds/Pont. They look like Ford. See page 4 for flange dimentions
    http://www.strangeengineering.net/
  11. TagMan
    TagMan
    You're absolutely correct - my bad.......I should have checked them before posting. I have no idea what they are. They don't show up on the Strange chart.
    Mounting bolt center-to-center distance is 3-1/4" across and 4-1/4 vertical. Nowhere near any Fords I'm familiar with. I know I got them with my Olds axle, but never tried to install them.
    Sorry for my screw-up. I assumed.......:eek:
  12. pila38
    pila38
    Pirated these from a "for sale" ad here on the hamb as a reference, there is also a pic in Fabcraft's book on 57-64 rears. Can't scan it though, no scanner to use. Hope these help some, they are missing a piece or two.
      79.9 KB
      76.8 KB
      76.2 KB
  13. Those look like Chevy Huck brakes
  14. Deuces
    Deuces
    What's a huck brake???
  15. DualQuad55
    DualQuad55
    from NH
    Huck brakes were the style chevy used before Bendix. They changed around 1952-1953.
    The pic of the brakes in question look to have heavy duty backing plates which used a different drum. The drums had a bell shape on the inside. I assume they would have been used on ambulances and such.
    I think there is a fairly simple way to swap 9in Ford Big bearing brakes, backing plate and all to the olds/pontiac flanges if need be. If I recall correctly it is simple such as redrilling two holes in each backing plate as two already match up. This would give you the 11x2 set up or others as needed.
  16. These aren't as purdy as Pila38's, but they're picked fresh from the tree, if you will.
