any help appreciated , factory 3spd on tree ,need photo ,print of linkage from floor board under ....
Need a bit of clarification. Are you wanting to see how the stock linkage hooks up....or....are you wanting to know about floor shift conversion?
Might look at this... https://www.hometownbuick.com/1955-buick-synchromesh-transmission-universal-joint/
There is a typo in section 4-10 on the second of two photos. Both are labeled 'Series 40 Transmission'. For the first photo that is correct, the second photo is the Series 50/60 transmission. Probably not pertinent to the issue at hand, but incorrect nonetheless.
thank you , what i need are a diagram or photo of pedal assembly linkage under the floor board ...this is a shifter on column .
