Just curious what sending unit to buy that will fit the Mustang gas tank and work with aftermarket fuel gauges. Cant seem to find out what sender to buy. Thanks boys, Jaison
The mustang tank sender is 73-10 so you will have to use that ohm fuel gauge, most aftermarket sources carry that range Mark
The easiest thing to do is, as Mark says, use the stock sender for the tank and get an aftermarket gage to fit. There are also "universal" sending units available for different Ohmn gages.
I have the mustang gas tank with the stock sending unit.When I ordered it I picked the 3/8 line . You can choose between the 5/16 or 3/8 fuel line.Depending on what brand of gauges you get.You can call there tech line and ask for the correct one for your gas sending unit.Thats what I did for my autometer gauges and it's pretty dam accurate.
Cool thanks guys, my biggest concern is the actual fit into the Goodmark mustang gas tank. Are all the sending units going to match the tank? Jaison
