Projects '53 Chevy truck - My crazy project
Discussion in 'The Hokey Ass Message Board' started by orula, Mar 8, 2011.
  1. I have an extra radiator support, but only the one set of the cross bracing. I can measure them when I go to the garage this weekend. I'll try and see if the top of the support unbolts. If you're interested
  2. I am sooo jealous, your truck is amazing! Your attention to every detail is top notch. I only wish I was closer so I could see it in person. This makes me want to get a truck as my next project. Thanks for sharing all your hard work. It is truly inspirational.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  3. orula
    orula
  4. Are you interested in the top of the radiator support if I can get it apart?
  5. orula
    orula
    Many thanks Hotskins :)
  6. orula
    orula
    Many thanks Kuztomklaus,
    I am very interested in those measures and your help would be greatly appreciated :).
    Thank yo so much
    Frank
  7. Okay Frank I'll get those measures for you this coming weekend. I'll take some pictures too.
  8. oldman2
    oldman2
    Allright Frank, got her running, sounds great, congratulations.....Jim
  9. I like the contrast.
    Gorgeous truck, lookin fine!:D
  10. orula
    orula
    Thank you so much :).
    We update next week
    Frank
  11. I have a picture of the factory core support. It has a lower horizontal brace and the x-brace. they are spot welded to the frame. 3/8" diameter rod with flattened ends is all it is. the top bar is also spot welded to the sides.
  12. yetiskustoms
    yetiskustoms
    i bet that truck stands out nice in rome!
  13. orula
    orula
    Thank you so much Yetikustoms,
    I must say that even now this truck arouses much interest, especially because it's an American truck.
    When this is over, make me mayor of rome :D:D:D
  14. orula
    orula
    Hi Nicolas,
    on my truck was missing lower horizontal brace and the x-brace.
    You can now determine the dimensions hole to hole of each brace?
    Many thanks for your help.
    Frank
  15. Frank, the lower horizontal brace is 22" long, each x-brace is 29" long. 1" of each end is flattened. Mine are spot welded on and they are also welded were they cross at the "X".
  16. oldman2
    oldman2
    Frank, I don't want to cause a problem about the X braces, but I also had to remove mine. I needed the front space for my condenser which was mounted to my Walker radiator. I did keep the top piece and the two braces that go to the splash apron. Here is the pic of when I first was fitting my stuff and the second in what I ended up with. Just wanted to let you know, what I did....Jim
  17. bigeasy
    bigeasy
    Yeah, I saw that too..funny, only because I spent some weeks looking for my delux. None the less - different strokes for different folks. He's doing a great job.
  18. AZbent
    AZbent
    Beautiful truck. If you want to do any painting on the hood ornament, paint the "Chevrolet" letter white like you did the "thriftmaster". That will tie it all together. keep up the good work. Mark
  19. I took a couple of photos of the spare radiator support I have, since it seem like you already got the measures you need, I didn't do those. Let me know if this is interesting.
  20. orula
    orula
    Hi Kuztom,
    your photos will be very useful to me.
    I will see how to strengthen my support.
    Frank
  21. orula
    orula
    Thank you so much Mark, great idea.
    Many thanks
    Frank
  22. orula
    orula
  23. orula
    orula
    I prepared a support for the solenoid valves (one in gray epoxy)
    but will be painted white.
  24. HEAVY100
    HEAVY100
  25. old injun
    old injun
    wow what a build,doing a great job. i just came across this thread and could not stop reading. im doing a 49 gmc and the pics are very helpful and yes 3 windows rule .
  26. c6_rob
    c6_rob
    Love it!
    ORULA, did you use a kit for the 4 link rear or was it custom. If so who did you use?
    Thanks
  27. No problem buddy. Anything for an AD friend! I could even find out how much it would be to send the whole support to Rome if you're interested.
  28. orula
    orula
    Hi KuztomKlaus,
    for now I try to change my support but I will consider your proposal.
    Many many thanks for your interest and your help.
    Frank
  29. orula
    orula
    Hi C6_Rob,
    yes, io have used a Heidts rear 4 link kit but I had to customize
    to lower the frame to the ground.
    If you want I can send you some pictures.
    Frank
  30. orula
    orula
    Today I painted the '55 chevy horns and installed chrome covers.
    I really like and would like to find a place for them to view
