Hot Rods 51 Flathead tear down and build up.
Discussion in 'The Hokey Ass Message Board' started by Aaron D., Feb 26, 2021.
  1. Aaron D.
    Aaron D.
    I'm a sucker for Flatheads. Found one on Facebook market place for to good of a deal to pass up.
  2. Pdstark
    Pdstark
    from Ca, Or, Mn
    Nice! I can relate to your video - except mine didn’t have quite as much gasket cling nor as much piston build up. Yours should clean up nice though. Hope there are no surprises you can’t address. Share your progress.
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    Great narration. No babbling on like most do.
  4. Aaron D.
    Aaron D.
    Continuing on with the 51.
  5. Really good video,,,,, and an excellent block as well .
    Should turn out to be a great engine !
    Tommy
  6. Fortunateson
    Fortunateson
    Great video. You sure got lucky with that block! However, I think that engine must have been kidnapped and taken into the US so when it's assembled bring it up to the border and I'll find a good Canadian home for it! LOL
  7. Aaron D.
    Aaron D.
    Thanks guys, and yes, very lucky. The guy said it was pulled from a running and driving car, I believe him now.:)
    warhorseracing likes this.
  8. Fortunateson
    Fortunateson
    Any updates?
    Desoto291Hemi likes this.
  9. Aaron D.
    Aaron D.
    Finally got around to posting an update on the flatty build. It's a little longer than I normally like to post but it's hard to put several hours of an engine build into 30 minutes of a video. Hope you enjoy.
    Christopher Miller likes this.
  10. Fortunateson
    Fortunateson
    Aaron, thanks for the update. I've been waiting as I will be going through this in a few months myself.
  11. Aaron D.
    Aaron D.
    They aren't all as easy as this one was.
    Working on the ignition system today and installing a PCV valve.
    I also need to make an engine run stand to start it up.
  12. v8flat44
    v8flat44
    Chack the cam. If it is an 8CM it is a very desirable cam.
  13. Aaron D.
    Aaron D.
    The cam says EA on it and has .335 lift. I think the 8CM cams have .305 lift.
  14. Fortunateson
    Fortunateson
    Aaron, can you post a video/how to regarding the PCV. Thanks...
  15. Aaron D.
    Aaron D.
  16. Fortunateson
    Fortunateson
  17. Aaron D.
    Aaron D.
  18. mink
    mink
    from CT
    Wow, thanks for posting. Clear and concise. Ready to continue pulling mine apart.
  19. Aaron D.
    Aaron D.
  20. getow
    getow
    Thanks for the time and effort put forth. But i think, that my vacuum port off my intake goes to the distributor advance? Can you still convert it to a PVC system using the same port?
  21. Aaron D.
    Aaron D.
    I’m not sure. But usually the distributer vacuum port is taken off the back of the carb.
  22. getow
    getow
    Hmmm. Ill double check mine. Good to know. I dont recall a vacuum souce from my carb consideringi rebuilt it. But that was a year plus ago. I remember it being from the intake to the distributor. It was probably plumbed wrong initially when i got it. If need be, is the intake port the same as the carb, or is the carb ported? Thanks for the info.
  23. Aaron D.
    Aaron D.
    @getow ,In the book written by Ron Bishop it states "Never connect the distributer vacuum line into intake manifold vacuum."
    The stock carb is ported.
  24. getow
    getow
    Gotcha. Will make it a point to correct it, if its what i thought. Thanks again. Awesome videos by the way. Hats off....
  25. Aaron D.
    Aaron D.
    Got started building an engine run stand. I just used what I had laying around. Ordered a radiator, hoses, and clamps.
  26. getow
    getow
    Looking forward to seeing that flathead running. By the way, you were right on the vacuum port for the distributor off the carb, not the intake. I have and rebuilt the wrong carb that dont have that port, ha. Go figure. But thanks to a fellow HAmber, i landed the right 1 locally. Happy Rabbits day by the the way.
    Aaron D. likes this.
  27. Aaron D.
    Aaron D.
    Finally received my water pump rebuild kits. I saved enough money rebuilding them myself that I bought a press to do them:cool:
  28. Fortunateson
    Fortunateson
    Aaron, thanks so much for posting this. Your videos will really help me reassemble my C8BA, with all original Merc guts, when I get back to it.
  29. getow
    getow
    Yes. Thanks for sharing. Info im sure ill need, sooner or later. Im kinda surprised on the lack of info given by the rebuild kit supplier.
  30. Aaron D.
    Aaron D.
