Desoto grille teeth 11 of them fit 50 merc. Does someone make these now reop?T I think i was told this a couple years ago can't think of the year. jus know they are the large ones ---51 maybe?
I've seen aluminum repops for sale before. I don't know why you would want aluminum, can't chrome it. Posted using the Full Custom H.A.M.B. App!
The 53 Desotos came with 11 teeth while the 51 & 2 came with 7 that you can use. My old Merc had 7 And the guy who bought it from me added two more (cover your eyes he isn't a traditional custom guy)
One thing to remember, All of those teeth are slightly different and there are lefts and rights and a middle tooth. I got the teeth and the pan when I put those in in the early 80's. I had to set down and sort them out more than once when I pulled them out to work on the metal around them.
thank you for the help! i appreciate knowing now that i need the 53 teeth .Thats what look the nicest setting up on a shelf is it? where does that come in .i mean what is the shelf out of?
I believe Gene Winfield makes a fiberglass lower grille shell to fit the Merc and hold the Desoto theeth my friend has one with the plastic teeth don't look to bad.
Sorry, I should have been clearer. I didn't mean you, I meant in general. I don't know why they make aluminum ones. Most people would want to chrome them. Posted using the Full Custom H.A.M.B. App!
You can chrome aluminum. Back when I still had the Merc I looked into getting the extra teeth I needed in aluminum and having the whole set chromed and or rechromed. At that time I think someone in Portland Oregon area was producing the aluminum ones and or refinishing the original ones.
"Radical Bill " Allen of Adams Wisconsin made these back in the early 90's before he passed. Not sure what material that they were made from.
Yep,chrome plating aluminum is possible.There are a lot of chromed aluminum parts on Harley-Davidsons.But i like polished aluminum parts better,its easy to do by yourself and a lot cheaper than chroming..
I will get hold of Gene see if hes got the plastic the alumu; Would go dull pretty quick without clear coating them. , I new once this post was seen- i'd get the info, very much appreciate all of yous help. bob cheers hamb!!
None that I know of right now. This guy specializes in used Desoto grills and teeth though. http://www.swapsellit.com/GrillBumper.html Most likely $$$$$$$$$$$$$$$$
WE all do!! or i do at least -do things to many times before i like it.Can't stop progress even if its wrong And hey thanks for "Butch bunns" address i know him and hes looking all the time for these grilles. Hes below me in ohio and i am 150 miles up from him . If i look long enoughand put A"grille kittty" away i can be ready when the right one does show up thanks all.yes on the$$$$$$$$$$$$$$$$$$$$$$$$$$$$ you are correct. bob s
