Projects 51 chevy coupe build
Discussion in 'Traditional Customs' started by 2345.coupe, Mar 5, 2020.
  1. brokedownbiker
    brokedownbiker
    Nice score, great car. One of my favorite cars, good luck with the project!
  2. Nice, hope you keep us in on the build, watching with interest.
  3. atomickustom
    atomickustom
    Random thought: if you need that missing rear window and it's the fixed version (glass does not slide) I have a pair in my shop with useable rubber. You can have them for the price of shipping or pick them up from the next HAMB drags. (Unless you plan to chop, of course!)
  4. J_J2
    J_J2
    Nice car! I’m building a ‘51 as well, good luck with your build I’ll be following!
  5. fastcar1953
    fastcar1953
    Nice car. Screams gasser to me. Even though they are the in thing. First to go would be the camaro subframe. it's to wide for the car.
    chryslerfan55 and Pist-n-Broke like this.
  6. Neb Hillbilly
    Neb Hillbilly
  7. thanks brokedownbiker...... really like the lines of this coupe.....
    yes Copper Top, I'll post my progress on this build.....have to finish my 29 roadster first.....
    Thanks atomickustom, I have the glass and rubber gasket....
    thanks J_J2m, I'll keep you posted
    Thanks fastcar1953, I'll have to research the camaro subframe issue
    I'm with you on the gasser build idea Neb Hillbilly
  8. fastcar1953
    fastcar1953
    stock track width is around 57 inches. camaro width is 61. tires usally hit the fenders and look wrong.
    Pist-n-Broke likes this.
  9. yeah .I'm researching it and there seems to be lots of problems......so what's the solutions
  10. 56sedandelivery
    56sedandelivery
    Having once owned a 51 Chevrolet Business Coupe, this car is definitely of interest to me. Looks to be in pretty good shape too (other than the front clip). I am Butch/56sedandelivery.
  11. fastcar1953
    fastcar1953
    new frame two door and four interchange. new front frame rails and turn into gasser.
  12. I might have a 67-69 subframe , I'll measure it up tomorrow. If so I should be ok
  13. she's solid and I'll fix the front end issues....
  14. fastcar1953
    fastcar1953
  15. chryslerfan55 likes this.
  16. dragginwagon2
    dragginwagon2
    from Ohio
    Unfortunately the subframe is already welded in but you can narrow it to fit if you want to re-do it. Me and some buddies in my car club did a '52 with a 67-69 clip. we narrowed it 4". That was 6 years ago
  17. Talking Sub Frames will get this post closed. I do like the project, looks solid. My best advice is to hang the fenders and see what ya got. 66/67 Chevelle is a much better fit except the steering box mucks up the Core Support and Rad fit. Change for the sake of change isn't always a good move. The factory stock stuff was also used under the Corvetts up into the latter years. As I remember it they were Bad Ass sports cars of the times. I also like the beam axle ideas however if you just want Kool factor and a driver I'd graph a stock unit back on but step it 2" while doing the repair, then it's low and you don't need to cut springs or dropped uprights.
  18. just bought a stock 52 4dr. ....problem solved...thanks for the good advice Pist-n-Broke and all the rest of you guys.....
  19. ...49 Chev, Nova clip (drum brakes help)..no issues...
  20. Rusty Heaps
    Rusty Heaps
    Definitely a good project car. Keep us posted on your progress.
  21. Old-Soul
    Old-Soul
    I've always liked the looks of "gasser" or drag cars without straight axles. Something about dropped front suspension and a raised stance looks meaner than hell to me.
  22. demon452
    demon452
    from Michigan
    Business or sports coupe? Here is my old 51 sports coupe.
    little red 50 and chryslerfan55 like this.
  23. not sure , all I know is the coupes have beautiful body lines......
  24. brokedownbiker
    brokedownbiker
    I may be wrong but I was told the difference is that the sports coupe had a back seat but the business coupe didn't. My old '51 was a business coupe but had been modified a lot when I bought it, it had a carpeted shelf built behind the front seats.
    And you are correct- these coupes are freaking beautiful!!
    bonneville bones likes this.
  25. Tri-power37
    Tri-power37
    Fat man fabrication sells upper and lower control arms for your set up that moves the spindles in a couple of inches a side. I put a set in a car a few years ago and the non stop tire to fender rubbing went away.
    296moon likes this.
  26. thanks , that's great information...
  27. deathrowdave
    deathrowdave
    from NKy
    I did one years ago , Mustang was the answer for a pan independent front super easy swap to stock frame . The stock Mustang crossmember was , super easy to use , worked fine . As far as a straight axle , early Chebbie works easy also with all the brackets the front of the frame is damn near the same in 37 - 52 .
