I have some assorted parts for 50's era Ford Flathead V8. Headers (one complete, and the other is tack welded and required finish weld before installed. These headers sell for $500. This set with the one needing finish welding I will sell for $175. <SOLD> two Rebuild-able fuel pump with vacuum pump. $35ea. Rare, original glass window washer tank. These are very rare due to being glass. Original and complete with frame. 1950's era. $90 Rebuild-able oil pump core: $30 <SOLD> EBA Type 94 Carburetor, original with Ford script (Holley made). This carburetor does run, and was last run about a year ago. I would rebuild it, but it does run fine as it sits. $70 If you take all (minus headers, they are sold), will sell the entire lot for $200. OR, I will also consider trades in part, or all. Stuff I need. International Harvester Scout parts, badges, Need a Holley 1904 single barrel carburetor, I need a 15" 5 on 5.5" pattern, 4.25" center bore (hub size) regular factory steel wheel. No hub cap nubs. Will consider same wheel with hug cap nubs if you have 4 matching. Make offers of cash and/or International Harvester parts. $175 for all that is left. (2 fuel/vacuum pumps, glass window washer canister, oil pump)
