Trying to get my swap into the old shoe box, but I can't figure out how to get the factory crossmember out ..I see 3 bolts on either side of the frame rail that looks to be holding the crossmember in.I removed all 6 and its still not moving is there something I'm not seeing ..please help.thanks
There should also be bolts on the top of the crossmember on either side. In total there 4 trans crossmember bolts per side.
Got it ......before I read this found 2 small gromets inside on the floor,popped them out and there they were 2 14mm bolts removed them and the crossmember fell out onto the floor.perfect Sent from my DROID device using the TJJ mobile app
They were 14 mm sorry if you had a diffrent size in your car ..but that's what I had Sent from my DROID device using the TJJ mobile app
