Hot Rods 4w disk brake system
Discussion in 'The Hokey Ass Message Board' started by EPestal, Mar 17, 2013.
  1. EPestal
    EPestal
    4wheel disk brakes
  2. EPestal
    EPestal
    I am installing 4 wheel brakes what kind of master should i run i am not using a power asist it is not going to be a heavy car the master is firewall mounted
    What kind of master should i run with a 4w disk system i plan not running no power asist the master will be on the firewall
  3. Morgan91
    Morgan91
    from Australia
    Bit more info, what size and type of calipers and rotors are you using? What sort of car? How longs your pedal going to be? What size wheels and tyres?
  4. Mike VV
    Mike VV
    from SoCal
    I'm using Wilwood, 4 piston calipers on all four corners of a car I'm rebuilding using a 1.00" Wilwood, dual outlet, remote resrervoir master cylinder.
    The piston sizes are equivalant to GM caliper, piston square inches (2.38" front, 2.00" rear).
    No booster...stops great.
    Using a simillar setup on another car I'm working on also. Just using actual GM calipers ("heavy"!!) in the front, and Ford in the rear...same piston square inches though.
    Mike
