Hey All, Exhaust is laying on the steering shaft, what headers have you used to clear the steering? Block huggers? Mack
http://www.sandersonheaders.com/Sanderson-CC50-Small-Block-Chevy-Header-Set.html You y have to check with them if it fits 48 steering
Speedway has fender well headers that might be the answer you are looking for. I used them on a 38 Chevy because the Mustang steering shaft took up too much room. $200 if I remember correctly. The only negative is that the exhaust is on the outside of the frame, in my case I was using floor mounted pedals and there really isn't enough room for the clutch linkage and brake cylinders etc and an exhaust pipe (at least for me)
