Projects 47 Coupe Build
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Dec 20, 2018.
  1. oliver westlund
    oliver westlund
    if i use late 50s olds or Pontiac i will have to have the axles drilled to accept 5x5.5 right?
  2. Darin Younce
    Darin Younce
    Will be a sweet ride . WIsh I had a different engine . Mines a 350 . Have a buddy that was stpck piling some early Chrysler fire power's I would love that swap . If you run across a dash , let me know . Mine has this ugly fiberglass thing that should be on a boat.
    oliver westlund likes this.
  3. oliver westlund
    oliver westlund
    i know a guy who has a dash, i think its a 47 merc dash
  4. The side trims are NOT identical... While the difference is subtle, mix the two and you'll quickly see the difference. Drake is selling '48 trim. If you have '47 trim and replace a few pieces from Drake you'll be unhappy when they don't match.
    '47 trim looked at end-on is teardrop shaped, '48 trim is V shaped. These are two passenger side cowl pieces, '47 on the left. This '48 piece has been 'repaired' so the peak on the V isn't quite as sharp as it's supposed to be but you can clearly see the difference from the end. The guy that sold me the '48 piece said it was the same as '47 too... nope.
    Now, Ford confused things by selling left-over '46s as '47s, and then started using '48 style trim on the late '47 models as a running change so the '47 got a reputation as a bastard year. And some parts are the same; grill, turn, and taillight trims are the same between the '47-48.
  5. oliver westlund
    oliver westlund
    i kind of like that my car is s bastard...feels more hot rod to me
  6. Steves46
    Steves46
    from Florida
    Looks like I learned something new today. Thanks for pointing this out.
  7. oliver westlund
    oliver westlund
    OK new option, 1953 olds 303, my question is this....if i put a 4 barrel on it and a cam, would a factory banjo rear and torque tube and a 3 speed floor shift ttrans hold up to THAT engine? just looking for opinions. i can get a 303 olds ridiculously cheap, he has the matching olds 3 speed but he said in the 50s he would mate em to stock running gear
  8. Torqueeeee engine, you would have to go easy with that banjo. Either way, I would grab that 303 along with the tranny and accessories just for the future. The tranny gut can be put into a 37 buick tranny case for a killer combo that wont break easily.
  9. oliver westlund
    oliver westlund
    can i rebuild the banjo in any type of period correct fashion to handle it?
  10. doubtful. It is all how you drive the car. Light 'em up and you will most likely break something.
    Hombre and oliver westlund like this.
  11. oliver westlund
    oliver westlund
    picked up a 38 ford motor and trans for 50 bucks today. output shaft gear is toast, are they all the same for 38s?
  12. 41rodderz
    41rodderz
    from Oregon
    You keep buying parts and engines , and Springfield recyclers will be calling you. :D
  13. oliver westlund
    oliver westlund
    yeah yeah haha, im selling the flathead and the 394 olds, im gonna use the 38 trans with the 1950 303 olds i have a fella holding for me. then i promise no more mind changing! i already ordered an adapter ring
  14. oliver westlund
    oliver westlund
    anybody know if all 36 ford main output shaft gears are the same? heres a pic finally 20190524_181007.jpg
  15. oliver westlund
    oliver westlund
    Hombre likes this.
  16. oliver westlund
    oliver westlund
    1950 303, the guy threw in a 53 4 barrel intake and carb
    Hombre likes this.
  17. good find! get the drive shaft if he had it. the front yoke might be a valuable piece. Last one I grabbed years ago with F&J down in MA fit the 50 Olds standard tranny. They are rare and expensive.
    My first rod back in '62 was a 47 coupe with a junk yard 50 303 hooked to a Lincoln 38-39 tranny. As kids we drove the pants off that thing and never blew up anything, which amazes me today.:rolleyes:
  18. oliver westlund
    oliver westlund
    im sure he has em, he has 3 of everything it seems like, super nice guy too. im running a 36 ford tranny and torque tube though
  19. rusty rocket
    rusty rocket
    36 tranny is not a synchronized unit. Seems like you are going backwards with the tranny choice. Just my two cents.
    oliver westlund and Hombre like this.
  20. Hombre
    Hombre
    I agree with "rocket" you may want to rethink that tranny, lots of better choices.
  21. oliver westlund
    oliver westlund
    i think it has later guts, that or i decoded the serial number wrong
  22. oliver westlund
    oliver westlund
    Thor1 likes this.
  23. oliver westlund
    oliver westlund
    tranny was pulled from a 32 that had a 38 flatty in it. also happened to have the throwout rod for my 47 with the pinched tab on the end coincidentally. itll work for me for now, paid 50 bucks for the motor and trans. selling the motor for 80 so i got paid 30 to have this tranny. im aiming my build date for 1952, thats the earliest my parts will allow
    Thor1 and Hombre like this.
  24. oliver westlund
    oliver westlund
    pics of the days ef fart, biggest pain in the butt automatic trans ive ever had to pull 20190603_162401.jpg 20190603_170248.jpg
    Thor1 likes this.
  25. oliver westlund
    oliver westlund
    cracked open humpty today, top end is surprisingly nice, cam lobes look decent. pretty darn clean for an engine that hasnt been open since 1950! im gonna do rings, main bearings, gaskets, timing chain and water pump unless i find some nightmare in the bottom. paint her up nice and factory only upgrade being the 53 4 barrel intake and carb which could technically also be from 52 which is why im dating my build in a 1952 traditional theme. she will be a bit of a sleeper (or wouldve been in 52 at least) cut off gas fill neck lakes in the fenders and a nice quiet exhaust otherwise. i believe a 36 ford 3 speed with later guts cause it has synchros and a 47 throwout rod, skinny white wall bias plys up front and either slightly wider bias plys in back (what it currently has) or cheater slicks, skinny ones of course, black laqcuer paint. all trim and hood ornament installed, white tuck n roll interior 20190606_102541.jpg 20190606_104701.jpg 20190603_133742.jpg
    Thor1, chryslerfan55 and Hombre like this.
  26. oliver westlund
    oliver westlund
    Okay its moving again! towed it out to the shop. I am going to pull the body off then haul the frame back down to my house so i can work on it when i have a second. Just going to clean up and paint the frame. Then I will set the 303 olds and 3 speed so i have plenty of room to design and fabricate motor mounts. I will probably not do anything with the body except patch the floors as of now, get it running, driving and stopping then i can do body work as I go. I thought it was cool the implement arms on the tracor fit the front of the frame perfectly! 20200414_114042.jpg
  27. oliver westlund
    oliver westlund
  28. oliver westlund
    oliver westlund
    Okay, whos gonna save me and help me find all the body mounts? I thought i had em all, put a jack under the body, no budge, air hammer to loosen the mounts, they popped free but still no lift
  29. razoo lew
    razoo lew
    from Calgary
    Here is a pic from an old thread here, may help.
  30. oliver westlund
    oliver westlund
    thanks! ill compare tomorrow
