Projects 47 Coupe Build
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Dec 20, 2018.
  1. oliver westlund
    oliver westlund
    cool, thanks!
  2. Be quiet paw, now go get me my shotgun, I thought I saw a certain wascalley wabbit.
    oliver westlund likes this.
  3. oliver westlund
    oliver westlund
    thats him to a t! he just helped his papaw load the trailer full of firewood, one little stick at a time
  4. oliver westlund
    oliver westlund
    much better thanks to a donated horn ring by a fellow hamber and a little paint! im thinking about trying to sand cast a horn ring out of aluminum...
    BigO, chryslerfan55 and slv63 like this.
  5. oliver westlund
    oliver westlund
    gave polishing my stainless a try...it turned out pretty good. itll work for my "driver" till i can afford some repopped stuff, i did 600 grit sanding, 2k grit then 3k grit then i used the 3 stages of the buffing kit followed by a stainless polish
    chryslerfan55, slv63 and topher5150 like this.
  6. There is no repopped stainless side trim for the '47. Everything out there is for the '48 only. There's guys out there that can restore your OEM trim and it won't be all that expensive unless yours is really trashed. I was missing the cowl pieces on mine when I got it (it had those POS aftermarket mirrors that you can't see anything out of), I tracked down a set of OEM bits that were pretty beat up. Got them straightened/polished for $30.
  7. oliver westlund
    oliver westlund
    i dont know that ive ever even noticed a difference between 47 and 48 side trim! mines pretty rough in a couple spots, I may just see about getting them fixed, thanks!
    chryslerfan55 and 48fordnut like this.
  8. oliver westlund
    oliver westlund
    i know its not the slammed to the ground look a lot of guys aim for but i seriously dig the stance of this car!
  9. The difference is the '47 trim is tear-dropped shape (looking at it from the end), the '48 is 'V' shaped with a peak down the center. It's only obvious when you have them side-by-side, it's really hard to tell from pics. The '48 trim will fit the '47, but you'll have to replace every piece...
    I paid more the trim pieces than what it cost to straighten them, seems like the cowl trim is the first to go missing. There's also two different hood trims; the early '47 has two little 'scallops' at the forward end of the trim, the late '47 is plain.
    48fordnut likes this.
  10. oliver westlund
    oliver westlund
    mine is plain but the entire front end of my car has been replaced too. i sure am glad you said something, i wouldve gone out and dropped 160 bucks on two pieces of door trim that wouldve severely pissed me off haha
  11. Yep, I almost did the same thing for my cowl trim until a guy set me straight.
  12. oliver westlund
    oliver westlund
    id help? i think the ones on the top are the cowl trim for my car, whats on the bottom? 20190223_194649.jpg
  13. Bottom is '46 trim; different yet again.... Somebody will want those...
    48fordnut and oliver westlund like this.
  14. oliver westlund
    oliver westlund
    this dang car and the boxes of mismatched stuff that came with it sure is confusing haha, its been off the road since 79, it came with all 46 guages, some 46 trim, it looks like i have 48 side trim possibly, ford fairlane front seat, no fender trim, a handful of half assed work previously done, its obviously exchanged hands and left parts behind at least once...sure wish i knew the entire history on it
  15. The upper cowl pieces in your pic are definitely '47 trim.
    BigO, 48fordnut and oliver westlund like this.
  16. oliver westlund
    oliver westlund
    okay good, then i have all the 47 trim! i will just get them repaired
    BigO and chryslerfan55 like this.
  17. Early 47's had 46 trim and hood "bird". 46-48 Fords were a miss-match as it was Ford going back to making cars after the war production.
  18. oliver westlund
    oliver westlund
    had no power for last 3 days, got a couple feet of snow, today it was back kn and i worked on a little traditional upholstery for the 47, dont judge too harshly, its my first time using a sewing machine haha
  19. banditomerc
    banditomerc
    Those pleats look great for first time out....I considered it on my last build...but got cold feet...
    Sent from my SM-J727T using The H.A.M.B. mobile app
  20. oliver westlund
    oliver westlund
    thanks! im going to practice a little on this 53 ford i picked up for 300 bucks, gonna paint it, new interior and drop a 460 in it and surprise gift it to dad for his birthday! then ill tackle my 47 interior
  21. oliver westlund
    oliver westlund
    so plans on the 47 have changed surprise surprise.... i have a buddy who needed a y block to trade for a 46 ford business coupe. im giving the 292 to him and he is gonna buy my bellhousing and everything i need to put the 394 olds in the 47! i think if im beimg honest thats what ive always wanted anyway, thanks for bearing with me and my many engine changing ideas haha
  22. The wheel looks great, and if you cast a ring do a thread for us to see.....
  23. oliver westlund
    oliver westlund
    will do!
  24. oliver westlund
    oliver westlund
    okay, i have a "period correct" question. i am definitely running my 394, probably gonna cam it a bit, 4 speed behind it, what period correct rear diff should i be looking for? on our local craigslist theres a 57 chev rear right now, should i be on the hunt for a 9 inch? 8 3/4 mopar? i feel like i need a list of decent options for a build thats pre 1964 that will hold up to that 394s power
  25. s55mercury66
    s55mercury66
    from SW Wyoming
    Personally, I would go with the 9" Ford. Easy to work on, probably the easiest to find different used gears for, and strong enough for most uses. The popular Bronco version may be tough to find, but pickup and van versions shouldn't be, if you aren't afraid to narrow one.
    oliver westlund and Hombre like this.
  26. oliver westlund
    oliver westlund
    narrowing one wouldnt be an issue, are there identifying styles that indicate date manufactured?
  27. oliver westlund
    oliver westlund
  28. If 'period correct' is important, what you'd find 'back in the day' would be a late '50s Olds or Pontiac. Those are scarce these days, so a 9" would be a semi-correct choice. A '57 Chev rear axle won't cut it...
    And just to throw this out there, another period correct choice that wasn't real common but wasn't uncommon either is a 3/4 or 1 ton truck rear axle. More than few guys ran these, as low ratios for racing were common, definitely heavy-duty enough, and most had full-floating axles so a broken axle didn't mean a wheel could come off. You had to run 6 or 8 lug wheels, but Halibrand and others offered wheels for them...
  29. Steves46
    Steves46
    from Florida
    The 47 & 48 trim are identical and I know Bob Drake was selling them. I have also seen them from time to time on E-bay. The 46 side trim is not being reproduced.
