Projects `47 Chrysler 3 window-Adding complexity.
Discussion in 'The Hokey Ass Message Board' started by lonestar395, May 4, 2015.
  1. lonestar395
    lonestar395
    from Australia
    There has been a Ton of work done here since the last post, and another Left turn regarding the finished product...the title of this thread is very apt.
    There has been some marginal body-work performed here decades ago, and I can't let it go. I have run the lead out of the factory joins and the old repairs, which then confronted me with more choices that had to be made, and it made it harder to preserve the original patina I was hoping to save...
    On a positive note, I have concluded the Jaguar front-end install and brake upgrade
    Yes...they are air bags in there...
    I am finally having a win with the body work, should see primer next week.
    Good news is the container has arrived from LA and the Jim Meyer Racing rear-end 4 bar kit will be available soon, and I can get it back on it's feet soon.
  2. so......4" roof chop?:)
  3. lonestar395
    lonestar395
    from Australia
    ...any time now, not much else here not modified.
    Got some inspiration from here...
  4. Top one, Sweet as (except for the fuel filler ;-) )
    Cheers,
    Drewfus
  5. Glad to be able to inspire you. Did you notice the forward stretch on the rear fender?
    That´s kind of important to balance the design.
    I assume it´s so short as it looks like Chrysler cheaped out and just used the same fender on the four doors as the two doors, but the standard item sure looks strange.
    kidcampbell71 likes this.
  6. lonestar395
    lonestar395
    from Australia
    Been spread thin in the workshop lately, however week-ends are for rubbing bondo (no pun there)
    I have finally got the body in primer...rear suspension upgrade next...
    kidcampbell71 and Drewfus like this.
  7. casper50
    casper50
    from alaska
    Looking good. I'm getting there. Waiting on a right rear fender to show up from the lower 48. Piecing together two trunk (Turtle) lids to make one. Then on to body work.
  8. lonestar395
    lonestar395
    from Australia
    Casper50, are you piecing together a skin to a frame, anything else would be a task...
    The Jim Meyer Racing rear end kits have arrived...not what I ordered though...must have made at least 6 International phone calls to them to refine this order, and I still didn't get what I wanted.
    The cross member and bracing for the factory parallel leaf rear will be removed, along with the bracing which is part of the inner boxing plates.
    The area will be reinforced with pieces fabricated and welded in to duplicate the rest of the frame and the 4 bar cross member will take the place of the factory cross member
  9. casper50
    casper50
    from alaska
    I have two trunk lids. The original is rusting on the bottom, the 2nd one was stored for years against a barn sitting on the top edge so it's rusty. I've cut the better bottom off and transplanted it to the original. I'm at work and don't have access to my photos. See the following almost to the bottom.
    http://p15-d24.com/topic/35504-started-the-teardown/page-14
  10. lonestar395
    lonestar395
    from Australia
    casper50, looks like you have got control of that trunk lid, I would have thought they would be heavier than they are, it is a large panel.
  11. lonestar395
    lonestar395
    from Australia
    Another big day setting up the rear 4 bar into the frame
    We have widened the 4 bar cross member for better fit into the Chrysler frame
    The cross member penetrated clear through the frame rails, giving a better purchase to resist torque loads
    The cross member was TIG welded into position
    We still have to create some clearance for the rear coil-overs to allow the rear of the body to lower onto the frame, however the stance looks killer, it has been over 6 months since we have seen the car back on it's feet, it will be a big motivation to push forward...
  12. mgtstumpy
    mgtstumpy
    I thought you were using an 8.8, that appears to be Foulcan rear end?
  13. casper50
    casper50
    from alaska
  14. lonestar395
    lonestar395
    from Australia
    I do have an 8.8 rear that lived in there for some time, and yes this is a narrowed Falcon Diff...jury is still out on final choice...Altra9 blew me out of the water with their quote for their 9" with 11" drum brakes @ $6,500.00
  15. lonestar395
    lonestar395
    from Australia
    The expected clash between the trunk floor and the 4 bar components is not as bad as I had expected, the upper coil over mounts, the diff housing back and the E brake mechanism were the only clearance issues...the spare tire well had to be removed and the trunk floor extended
  16. waynos
    waynos
    The stance looks awesome in that last pic
  17. lonestar395
    lonestar395
    from Australia
    The clearance holes for the rear coil-overs cut in the trunk floor have been capped with covers formed in the Pullmax, which allowed me to prepare and paint the trunk interior...bit of a milestone for me...
    The frame was rolled out from under the shell to finalize welding the 4 link rear components that were previously tacked in place
    kidcampbell71 and ratty_aussie like this.
  18. casper50
    casper50
    from alaska
    Looking good. First paint is a great feeling.
  19. You're doing fantastic job. These big butt MoPars really have some character even though the big crowd seems to disagree.
  20. Sure will.
  21. lonestar395
    lonestar395
    from Australia
    I have been going to add more content here for the past 2 weeks, just too burned out when I get home from the workshop...
    We concluded the rear end install
    Then stripped the frame bare to abrasive blast and paint
    Because there was some thought of doing a rub through paint job, I laid down some 2K red oxide color
    before wet sanding and applying the Military Blue top color
    I am now beginning to reassemble the components to the body and get it mounted on the frame...
  22. That blue is really nice.
  23. casper50
    casper50
    from alaska
    very nice. I can't wait to get to that point. Getting there soon.
  24. lonestar395
    lonestar395
    from Australia
    Had a bit of a win today, the rubber parts from Steele rubber were cleared through Customs, as well as the Fulton 800 Visor purchased through the HAMB for sale section...that means I can now get the frame bolted up under the body, and other parts concluded.
    More panels hung and adjusted...
    Drewfus, kidcampbell71 and kiwijeff like this.
  25. gatz
    gatz
    I like this Military Blue color....
    What is the paint code # or source?
  26. lonestar395
    lonestar395
    from Australia
    Dwight, I mixed the color on the bench here from left over paints from previous jobs...essentially it is based on Kingfisher Blue with black and white added until I came close to matching an area of original paint under the hood.
    There are paint pages out of original color books on ebay under 1947 chrysler which show color names and codes
    ratty_aussie and Peanut 1959 like this.
  27. Peanut 1959
    Peanut 1959
    Love the resourcefulness on the paint! Way to go.
  28. Looks brilliant! That military blue is really nice.
  29. lonestar395
    lonestar395
    from Australia
    Front sheet metal has been abrasive blasted then Epoxy coated and I am now working at getting it straight
    All this adds another dimension to the build process...clearly I can't live with a ratty car.
  30. lonestar395
    lonestar395
    from Australia
    Moved forward another notch
    Been getting deliveries of parts required to assemble this almost daily, they are a complex car...
    Drewfus and tomkelly88 like this.
