Auctions
47 Chevy Coupe
Discussion in 'Cars For Sale' started by Freemoe, Mar 4, 2020.
  1. Freemoe
    Freemoe
    from Fowler, CA
    City: Fowler
    State: California
    Price: 12k
    Perfect car for someone to finish up and make it their own. Have a clean California title on non-op.
    1947 Chevy Fleetmaster Coupe, 350 Chevy with Edelbrock, pictured with a Holley. Turbo 350 transmissions, new Lokar shifter. The rear is a Ford 9in geared at 3.00. New disk in the front and new drums in the back, all new brake system. New radiator, new wiring, and fuel system including a new tank. New rims, tires and front glass. The body has been media blasted and por15 was used under. Some surface rust has developed but should not be a problem. the door and rear fender were welded by the previous owner and there is slight warping. The car is very close to being a very reliable driver, needs some tuning. I only put about 200 miles on the car.
    There is more that comes with the car like skirts and heater as an example. 00B0B_52EIHWL4hKN_600x450.jpg
  2. Freemoe
    Freemoe
    from Fowler, CA
    Bump, new lower price!
  3. Freemoe
    Freemoe
    from Fowler, CA
    Up for sale again.
    Update: Did some work on the car. It's running and driving and put about another 200 miles on the car. There seems to be no oil leak from the engine but the transmission does leak. Seems to be common for a TH350. Was going to get a new seal for the pan and shifter shaft to try to stop it. Painted the rims black and put 4in lowering blocks, I have the 3in blocks and recommend putting them back as it does bottom out on a slight bump.
    53belairpdx, curbdogs and bobss396 like this.
