Ok, I have searched this site high and low and can not find an answer to my problem. I have a set of '42-'48 lincoln front brakes and I would like to remove the hub from the drum for media blasting. However, I can not get them to come loose, is there some trick that I am missing? Please help.
They are not made to be disassembled...they were sold only as a unit. You would have to press out studs, get new studs, and swedge the shoulders of studs with a really heavy press. They would then likely need turning to gettem centered again... Don't!
Attention: Attention: If you follow the advise to press out the studs you can ruin the hubs. Ford and Lincoln studs are swedged to the hub and drum to assemble the unit meaning that the stud shank is mushroomed out under pressure to joint the parts together as a unit. If you use a press to push the studs out this elongates the stud hole and you cannot get new studs to fit or worse you crack or bend the hub. If you have good drums just leave them assembled.
