For Sale: 392 Hemi HI Pro 375hp engine. Original dual quad manifold and carbs. Std bore and crank (both mains and rods). new rings, rod and main bearings and cam bearings. New 340 high volume oil pump, adapter, drive and pickup from Hot Heads. New Melling roller timing chain and gears. Adjustable rocker arm assembly, including new shafts rebuilt by Rockerarms Unlimited. New Isky solid lifter cam with original lifters reconditioned by Rockerarms Unlimited. Hot heads aluminum timing cover w/acc mounting provisions. Aluminum valley cover. Aluminum BBC water pump w/Hot Heads adapters. Heads pressure tested, resurfaced, new guides and fresh valve job w/ hard inserts for exhaust valves. 318/340 electronic distributor. Hot Heads screw on oil filter adapter. Engine and heads professionally cleaned and rebuilt/assembled.Original Hi-Pro valve covers for adjustable rockers, powder coated. All new Fel Pro gaskets. All original extra parts included. Call Robert @ 530-529-0148
