Technical '39 ford tranny
Discussion in 'Traditional Hot Rods' started by arvonian, Sep 7, 2013.
  1. arvonian
    arvonian
    from Virginia
    Is there any quick way to tell the difference between a '38 and '39 tranny?
    I was told that the 39 has a stronger case than the 38... One advertized locally as a '39, but would like to be able to verify if I go to look at it.
  2. 117harv
    117harv
  3. George/Maine
    George/Maine
    The 39 and truck tower will have a 3" fork, the gears are weak not the case.
  4. arvonian
    arvonian
    from Virginia
    Thanks guys, this FNG still hasn't found the easy button (search!):confused:
  5. The cases are the same. Both years will have a "78" on the case showing it was first used in 1937. The important difference is in the gears. To complicate maters some '39 used the '38 gears so can't just go by the serial number, you need to be sure you get the desired gears and tower. If it is supposed to be a "39, do a search to learn how to identify the correct gears and tower. You can probably find the information you need at http://www.vanpeltsales.com/FH_web/flathead_home.htm
    Charlie Stephens
  6. Andy
    Andy
    Take the top off and look at the sychro coller. If the fork groove is at the rear, it has 39 type gears. The top should be marked 81-xxxxx for the interlock style.
  7. flatford39
    flatford39
    I have a few 78 cases and a recently rebuilt 46 48 transmission. I am going to put those gears into my 78 case as they will be an upgrade because of synchros etc from the 37 39 gears. I am doing this because I want a top shifter. You will need the #81 top shifter with the 3" forks to make this work.
  8. arvonian
    arvonian
    from Virginia
    I'm thinking this internet thing just might catch on! Thanks for all of the info.
    Checked my '38 trans., 78-7006 case and 81A-7222 shifter housing. So, I'm thinking that the '39 gears would be an upgrade due to the improved synchros?
  9. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Now to throw a wrench in, I put 46 6 cylinder gears in my 39 case.
  10. Carter
    Carter
    Pull the top and measure the big fork. If it's 3", you've got the 91A fork and later synchro. If it's 2 7/8", you don't.
    I've never felt it was such a huge deal. Ford three speeds were synchronized on the 2-3 shift from 32 on. The synchro and shifter housing were improved a few times between then and 39, but I always wondered if it was really that big of a deal. I'd imagine a worn out 39 box would shift just as terribly as a worn out 34 box.
    I don't have much trouble shifting the stock gearedB trans in my A.
  11. 1941coupe
    1941coupe
    the early forks are 2 3/4 later 39 up have 3" forks also the double detent plugs are 5/8 as per mac van pelt site,
  12. Carter
    Carter
    The 81A top is double detent. Prior to that they were single detent(not counting V8-60). Not all 81A tops have the 3" fork, though.
  13. My '40 coupe has a '40 p/u transmission. Any difference between the '39 pass car and '40 p/u trans.
  14. Andy
    Andy
    Clutch release shaft different.
  15. Fortunateson
    Fortunateson
    I have a '46-48 truck tranny and a '40 car tranny with Zephyr gears. Will swappy the Zephyr gears into the truck tranny case be a big deal? It;s going into a '32 5 window with a '40 rear end. I hope the only real big deal will be converting the rear end to open drive or can the '40 torque tube attatchment be used on the 'truck tranny ?
  16. Fortunateson
    Fortunateson
  17. Bruce Lancaster
    Bruce Lancaster
    Pretty much all of what you need to buy the right stuff is in this old post: I tore all the tips out of "Consumer's Guide."
    http://www.jalopyjournal.com/forum/showthread.php?t=91515&highlight=39+trans+prices&showall=1
    When talking about the ""39 trans", always be aware that roughly half of TRUE ones, the ones out there with an actual '39 serial number, had the '36-38 type innards and not the late synchro/big fork, and that the type of trans everyone actuall wants can be built out of a wide variety of Ford parts of different years.
  18. Andy
    Andy
    Also, the true 39 box had a unique clutch arm. It is designed to be used with the odd 39 pedals. I have a dimension hid somewhere if somebody need it.
  19. Bruce Lancaster
    Bruce Lancaster
    Most actual uses will require arm change and change of rear mount to fit chassis in question, and in a tight cockpit like a Model A choice (or bending) of shift lever may be critical.
  20. gasheat
    gasheat
    from Dallas
    My friend Andy is a smart guy.
