1937 top shift lasalle with 50 olds tailshaft conversion. This is fully rebuild, nice and tight. The nicest one I’ve ever owned. On the bench it shifts like a dream. New sealed front bearing, nos rear slip yoke seal, the synchro looks nos and I mean it has no wear at all. All the gears are perfect along with the thrust washers. The countershaft and reverse gear shaft have been o-ring so it won’t leak any gear oil. The shifter is stock length and in great shape. I fab up a rear trans mount to use a standard gm mount. SOLD.....plus shipping or pick up in Tx Also comes with new clutch disc.
