37-38 Chev Coupe, problem areas?
Discussion in 'The Hokey Ass Message Board' started by johnod, Oct 11, 2012.
  1. johnod
    johnod
    I'm hoping to look at a 37-38 Chevy business coupe soon.
    Are there any known problem areas i should look for?
    You know, something they are prone to, certain ares rust out, bad frame , anything of that nature I should look for.
    Appreciate any model specific help you can offer.
    Thanks
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Rockers, lower area behind the doors, and tail pan are prone to rust. patch panels are available for all the problem areas.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Tailpan rust out in the bottom area is a problem on most 37-39 Chevys, just like the 37-40 Fords. Also look for bondo covering a really mangled pan.
    Lower quarters between door and rear fender are a repository for grit, grime, water and rust buildup.
    Lower front door posts where they meet the rockers are often eaten up.
    Cowl vent trough can be crunchy as most have the vent drain clogged.
  4. mr.chevrolet
    mr.chevrolet
    it's a coupe, buy it. you can buy every patch panel you'll need from EMS.
  5. johnod
    johnod
    Thanks, i'll be sure to check these.
    Anyone got anything else to add?
  6. Normbc9
    Normbc9
    Mine is old and I get all my body panel parts from either Chevysoftheforties or The Filling Station and both have good products and service.
    Normbc9
  7. MrBullet
    MrBullet
    The EMS tail pans require a lot of work to make them look right
  8. johnod
    johnod
    Thats a good looking coupe, I'd be happy to own it.
  9. johnod
    johnod
    Thanks, good to know.
  10. johnod
    johnod
    Well my deal fell through, so the search continues.
