Hi Currently putting together a '33 Ford truck, rear end will be a closed drive V8 QC with '41 axle tubes, '36 radius rods, '36 drive shaft and either an A or T spring. As the axle tubes were in great condition I decided to use em and chop the spring hangers off, and intend to fab some mounts for the '36 radius rods (yeah I know, why didn't I just get '36 axle tubes too?!). Anyone know what the center to center distance is between spring hanger eyes on the '36 radius rods when fitted on a stock '36 axle? I will probably go with the T spring as I prefer the look over the A spring, will this work OK on the above set up? Thanks!
