Getting new engine on monday figure might as well get a new water pump since mine has seen better days by the look of it. Any recommendations on one I can pick up on amazon for ~30 bucks or a local parts store? I need short neck and I believe clockwise rotation if its being driven directly off the crank pulley correct? Not having much luck searching on my own many of them don't say rotation or if they're long/short, Thanks.
I may be treading dangerously, my new pump is a shortie since my set up is between a '65 and '68 Impala. Got it off eBay delivered in 2 days for $17.95, free shipping and is the Cardone brand. So far so good, but recommend something a little better to anyone else.
I picked up a GMB one off amazon for 30 bucks, thing got here damn near faster than if I had gone out and picked one up myself. Thanks as always.
There are different “short” pumps. Check to see what you have before ordering a replacement. A 68-70 “Corvette” pump is “short” and has the heater hose on the side, 9 o’clock position. Other pumps have the heater hose exit on top, 12 o’clock. On the 68-70 pump, the shaft diameter is 3/4”. 71 and up, the shaft is 5/8” diameter, and 3/16” longer than the earlier pump. If you want your pulleys to fit, and line up, check your pump shaft diameter first. Sent from my iPad using The H.A.M.B. mobile app
