I have a 35 36 Ford wishbone that has egg shaped shackle bushing holes. Any repair advice, links etc.? Thanks
I have replaced the bushing receiver part with a piece of D.O.M. It required some hand work but welded up just fine. Getting it aligned properly was the challange. I couldn't see how to machine and bush the factory part back to O.E. inside dia. The Wizzard
Insert a piece of 3/4 brass stock in the hole, then grind the bad spot and weld it up ,remove the 3/4 stock whatever way works..
