Full fendered 'glass body on original 34 Ford frame - straight body of unknown manufacturer - good fit and gaps - lift off top - 3 pc hood w/hinge kit - aluminum grille insert - aluminum radiator - original Mustang II frt suspension - Ford differential on parallel leaf springs - crate sm blk Chevy w/ 2-4 bbls - headers - Flow Master exhaust ( needs tail pipes ) - 700R4 automatic - column shift tilt column - under floor power brakes - pedals hung - brakes plumbed - fuel lines run - steering done - bear claw latches - big & little radials on steelies with trim rings and caps - most all parts to finish like head and taillights, gauges, switches, wiring, suicide locks and more including correct 34 Ford roadster title - very easy finish - need funds for business
