1934 Sedan delivery , frame off restoration, all steel body original Henry , repo Rootlieb lovered hood . Powder coated frame, 39 Lincoln juice brakes, backing plates, dual master, superbell dropped front axle 39 toploader Lincoln Zepher gears, two-speed driveshaft borg warner planetary closed line on pedestal to 3rd member. Complete re-build, 1948 59 AB, Evans Alum heads, Winfield cam, Merc 4 1/4 crank , 30 over pistons, Johnson lifters,Thickstun pm-7, Fenton headers, Holley 94s , Botteger chrome domes, alter-gen single wire, electronic ignition ,rad recored. 40 sterring wheel , 32 roadster bench seat, . interior new matching perfect wood, insulated , no panels. Have all interior tins, some painted some not Filled roof from 1940 Cad limo, perfect crown and curve. Single stage cocktail ovlive green paint, UPS brown belt line, Rory painted red pinstripe. One off wheel caps and taillights with leds. Powder coat wire steelies punched and welded, Uniroyal bias. 39 Lincoln juice brakes Needs speedo hooked up, shims for lash in differential , some noise coming from there and maybe a need to re-wire , the Ron Francis looks hoaky and is under wired. New Optima battery. Starts up with a 1/4 turn sounds really great. Located in Nor Cal, Emeryville, Oakland Clear pink/title, partial trade for 65-66 Mustang fastback, no projects please. Contact Gary at [email protected]
