This is the old mans pile of hemi parts. 331 and a 354. Looks like enough to build both engines. 2 blocks 1 with internals in it main caps 1 crank fresh grind no bearings 2 flywheels 4 exhaust manifolds, two are the really good ones 3 intake manifolds 2-4bbl 1-2bbl 1 transmission 6 heads some with valves some without rods and pistons road draft tubes pulleys spark plug tubes transmission coolers water pumps 2 sets valve covers w/wire covers 2adapters for transmission rocker arm assys cam shaft/ chains and gears oil pan valley cover timing cover
