Projects 33 Ford 5 window coupe build - 50's style
Discussion in 'Traditional Hot Rods' started by ss34coupe, Feb 3, 2008.
  1. ss34coupe
    ss34coupe
    That would be great if you could post some pics of how you mounted the generator. That is one of the things left to work out on this build. Thanks for any info you can provide.
  2. AHotRod
    AHotRod
    Anything new ?????????
  3. ss34coupe
    ss34coupe
    The coupe is sitting up on the hoist waiting for brake lines and exhaust to be installed - will hopefully get to that next month. Other projects, some of the non-car kind, are taking my time these days.
  4. ss34coupe
    ss34coupe
    Back working on this long time project - too many other projects have got in the way. Here are pics of the dash and the exhaust system - working now on installing the glass. More pics to come. IMG_1323.jpg IMG_1316.jpg IMG_1317.jpg
  5. Looking good Steve. no chrome exhaust tips, a real hot rod.
  6. Deuce Shell makes it, in the 50's there were no 33's if you got one the first thing you did was put a 34 grill shell on it, but my favorite 34 had a deuce shell like yours, you're on to something.
    48fordnut likes this.
  7. Duke
    Duke
    Looking good, should be ready for a cruise soon!
  8. ss34coupe
    ss34coupe
    The reaction to the 32 grill shell has been mostly negative, guys think I should run a 33 grill.
    But I'm with you John, they used Deuce grills back in the day on channeled 33-34 Ford coupes, and I have always liked the look they provide. So the 32 shell stays!
    Stogy and duncan like this.
  9. MR CLEAN
    MR CLEAN
    Your doing a excellent job on your '33 Five Window Project. Build your vision since it is your time and money.
  10. ss34coupe
    ss34coupe
    Thanks for the kind comments, guys!
  11. A 27 Whippet shell would look really good, nod nod wink wink.
  12. ss34coupe
    ss34coupe
    Ron, you know a Whippet grill is not going to work on this coupe, but would look great on an old speedster. Someone out there needs it for their build.
  13. ss34coupe
    ss34coupe
    Here is the deuce grill shell ready to be installed. Was shortened 4 inches many years ago, I am told in the early 60's - was on a Model A roadster. The insert needs some work but will be used in this project. IMG_1328.jpg
    kidcampbell71, MR CLEAN and loudbang like this.
  14. ss34coupe
    ss34coupe
    Got a working cowl vent now, finally put the pieces together. The white you see here is the back side of the dash - makes it easier to see behind there when everything is assembled - a little trick I came across many years ago. IMG_1325.jpg
  15. ss34coupe
    ss34coupe
    Hamber Duncan supplied the drag link, and he reamed the opposite side of the 35 Ford pitman arm so that the tie rod end could be mounted to provide clearance for the radius rod. There is nothing that beats rodders helping each other out! IMG_1326.jpg
  16. Nailhead A-V8
    Nailhead A-V8
    The main reason I love the '33-4 Ford is the beautiful streamlined grille so I honestly never understood putting the deuce grille on them. In my opinion the style came about on the east coast because the deuce coupe was so iconic... if you couldn't find a deuce you put the '32 grille on a '34 but that's just a guess....anyway looking at the picture of this car I suddenly realized my major objection had always been that most of the '50's cars put the '32 grille/rad way out in front of the crossmember and many compounded the issue by using spring in front axles creating a tractor like appearance especially when the headlights are placed way back....when placed in the right position in relation to the front axle/headlights it looks really cool.... but no longer '50's east coast style
    loudbang and ss34coupe like this.
  17. ss34coupe
    ss34coupe
    Nailhead A-V8 - you described it perfectly. To look right on a channeled 33-34 Ford coupe, the deuce grill should be in line with the front axle and headlights. Have seen too many that are mounted forward of the axle, and to me that does not look right. On a channeled coupe, it also helps to have a sectioned grill shell. Thanks for the comments and observation!
    Nailhead A-V8 and loudbang like this.
  18. Nailhead A-V8
    Nailhead A-V8
    This car is going to be sweet....hope you post a vid of that caddy so we can hear it running!
  19. sloppy jalopies
    sloppy jalopies
    nail,
    IMO... when you remove the hood the grill doesn't hide the ugly sides of the radiator... that is why I ran the chopped '32 shell on my '33 fiver...
    IMO... a '32 shell on an A was because the '32 radiator upper tank peaks forward, the A shell was not,
    if you ran a flattie you needed the '32 rad. and of course it's shell...
    Nailhead A-V8 likes this.
  20. ss34coupe
    ss34coupe
    Got the "Tanks" gas tank installed in the trunk and vented through the floor. Need to get a sender and install the gas line next. The ammo box will be the battery box. IMG_1344.jpg IMG_1346.jpg Also putting in the glass now, here is the rear window done.
    Vic Walter, brEad and loudbang like this.
  21. Looking good Steve.
  22. ss34coupe
    ss34coupe
    Thanks, Ron. Got some red oak installed so all the wood pieces are now in place. Put the original woodscrews back in place, always keep that type of thing just for this purpose. Slowly but surely this build is coming together - on to the rest of the glass next, then the headlights and taillights....... IMG_1351.jpg
    ls1yj, duncan, Nailhead A-V8 and 2 others like this.
  23. Blake 27
    Blake 27
    ls1yj and loudbang like this.
  24. Steve hit right on the main reason for using a '32 grill on a 33/34, that has been channeled OR sectioned. When you lower the body, you need to lower the grill to match. After you stuff a 33/34 grill 5" or so closer to the ground, they are dangerously close to the pavement and tend to look longer than normal maybe even out of scale to the body. The '32 shell is about and hour or so worth of cutting and welding. Can you imagine sectioning a 33/34 grill???? There's a few in magazines and they can look kinda "off" as well. Sure wish I had put one on my cabrio. Tim
  25. see above post
  26. Blake 27
    Blake 27
    Vic Walter, ls1yj and loudbang like this.
  27. ss34coupe
    ss34coupe
    Blake - thanks for the pics of the generator and mount - gives me some ideas! Tim, thanks as well for the comments. Often the best perspective comes from people like you that have actually built a 33-34 Ford. Did you sell the cabrio?
  28. Yep! Bought a '33 sedan in January and sold th
    e cabrio in April
  29. ss34coupe
    ss34coupe
  30. ss34coupe
    ss34coupe
    Installed 1937 Ford taillights and rear license plate mount - pics up soon.
