Projects 33 Ford 5 window coupe build - 50's style
Discussion in 'Traditional Hot Rods' started by ss34coupe, Feb 3, 2008.
  1. old hickory
    old hickory
  2. old hickory
    old hickory
    I know this is an old thread but I’ve been on the hunt for a coup too.
  3. old hickory
    old hickory
    jakespeed63 likes this.
  4. ss34coupe
    ss34coupe
    yes, this build started many years ago. Worked on it from time to time, but kept getting interrupted by buying other projects. Thanks for your comments. Keep looking and you will find that coupe!
  5. fordgezzer
    fordgezzer
    from texas
    All it takes is time and money.
  6. ss34coupe
    ss34coupe
    image-1.jpg yes, they are still out there. So keep looking if your dream is to build a 33-34 Ford coupe. And check out Hamber Duke's 34 coupe in the for sale section.
  7. ss34coupe
    ss34coupe
    Haven't talked much about the engine and driveline details in this thread. The 1953 Cadillac motor is a stock rebuild - and here you see the stock fuel pump. It did not work very well, so installed an electric fuel pump inside the rear frame rail. The gas runs through the stock pump, which has a plate inside to prevent gas going into the crankcase. Not difficult to do, and keeps the motor looking stock. The trans is 39 Ford and the rear axle is 40 ford, with Hotrod Works axle conversion. The wiring is old school from scratch - no wiring kit here. IMG_3018.jpg IMG_3041.jpg
  8. Duke
    Duke
    Nothing better than an Early Caddy!
    loudbang and Nicholas Coe like this.
  9. Ruby32
    Ruby32
    Love caddys
  10. ss34coupe
    ss34coupe
    All the chrome parts on this coupe were chromed back in the day. The front axle was the start of this build - bought it in the 90's off a fellow who was changing over to a tube axle. Had to buy a complete motor to get the chrome engine pieces, but that motor is now slated to go in a friend's 39 ford coupe.
  11. ss34coupe
    ss34coupe
    The crank pulley and fan extension have been in my garage since the late 60's - I was a teenager then. Glad I finally got to use them. No, not the same garage, gone through a few over the years.
    brEad, loudbang and AHotRod like this.
  12. AHotRod
    AHotRod
  13. BobbyLaMalice
    BobbyLaMalice
    from France
  14. Hotrodder28
    Hotrodder28
  15. ss34coupe
    ss34coupe
    Thanks for the kind comments.
    Nicholas Coe and loudbang like this.
  16. ss34coupe
    ss34coupe
    Using the Early V8 Garage hydraulic conversion kit. Very impressed with their product and service. IMG_3049.jpg
    Vic Walter, brEad and loudbang like this.
  17. ss34coupe
    ss34coupe
    The coupe has Buick finned drums up front, and repro Lincoln brakes on all four corners. Using an F1 steering box, gave plenty of clearance for the Cadillac exhaust manifold. IMG_3022.jpg IMG_3024.jpg
  18. ss34coupe
    ss34coupe
    Check out the dash - mostly old SW instruments picked up at swap meets. The inside door window moldings are cut down tudor units. IMG_3026 (1).jpg
  19. Outstanding hot rod in every way. Love it all.
  20. ss34coupe
    ss34coupe
    Thanks very much!
  21. ss34coupe
    ss34coupe
  22. ss34coupe
    ss34coupe
    Thanks to my friends Lorne Friesen, John Aasen, Keith Smith and Al Gunnarson who helped a lot during this build. Thanks also to Syd Moorhouse for the carb rebuild and for sharing his great amount of hot rod knowledge. Thanks also to my up island friends Ron Greenfield and John Vicars for their help on the project. Never say "you built it yourself" - friends are always there to help get the job done.
    brEad, loudbang and Nicholas Coe like this.
